Sharpening system advice...final tweak to my setup?
« back to Hand Tools forum
Forum topic by bbasiaga posted 12-29-2017 04:27 AM 1882 views 1 time favorited 17 replies Add to Favorites Watch
View bbasiaga's profile
bbasiaga
1233 posts in 1993 days
12-29-2017 04:27 AM
Hey all,
Like many others, I have gone around a few blocks figuring out what I need for sharpening. Here is what I have
LV MKII sharpening jig
Inexpensive homing guide
Coarse DMT diamond hone
Fine DMT diamond stone
KING 1K/6K combo.water stone
Norton 4k/8k combo water stone
Grizzly Tormek knock off
I usually sharpen by hitting the diamond plates and 8k side of the stone. I only use the grizzly for big reshaping jobs and my carving chisels . I basically don’t use the 1k/6k any more. I started with that when I got a set of chisels, but don’t use it too much, and it is too narrow for most plane blades.
The main issue I have is that the water stone is kind of a pain. I keep it in a jar so it is wet and ready to go, but moving all that off the shelf to my bench and back is extra steps. I am not super happy with the diamond plates…they do fine but the water stones seems to cut much faster and leave a better edge
I was thinking if I were to start today, knowing what I know, I would stick with the coarse diamond plate to flatten my water stones, and get a 1k and 8k stone from LN or Shapton – which don’t require soaking, just a little spray. The fine diamond stone is pretty new and works as the ~1k step, so I will keep that. If I got an 8k stone from LN or shapton, I would have a water jug free set up. I could make a sharpening board and keep it closer at hand, spend less time setting up a d cleaning up.
Is it worth the extra money? I have the money, but I do have a functional, all be it frustrating system. If i dont spend it on this, i could get some other tool or project limber or something. Advice?
Brian
17 replies so far
View AandCstyle's profile
AandCstyle
3052 posts in 2255 days
#1 posted 12-29-2017 10:56 PM
Brian, I see things like this as barriers. Your current system is a bother so you probably don’t do it as often as you should and it takes away from your joy of woodworking. Buy the Shapton and and the barrier will be gone. FWIW
-- Art
View Holbs's profile
Holbs
1867 posts in 2027 days
#2 posted 12-30-2017 01:35 AM
I have all grits of EZE-LAP diamond stones (slightly inferior to DMT due to different diamond structure but more affordable) and I rely heavily upon them. However, I just recently found out they make diamond plates for my Worksharp 3000. Going to give that a try after the new years.
I have no water stones or oil stones.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
View TheFridge's profile
TheFridge
9463 posts in 1484 days
#3 posted 12-30-2017 05:58 AM
I think the ezelaps are better quality than my dmt gear.
I bought some shaptons last year ish. 1k/5k/8k. I don’t have a sink in my shop so I wanted something ready to go with a squirt. The stiction can be pretty bad on the 2 higher grits but I’m used to it. They work very well for me though.
I don’t use diamond stones as part of my process. They are there to flatten the water stones on the rare occasion, and for setting up new irons or heavy primary bevel work. And odd and end stuff.
I could use just the 1k, 8k and strop if I needed for regular sharpening.
Edit: find what works for you. If you can afford it go for it. I hear the sigma power 2s (or something like that) are preferred over the shaptons. I think you have to get them from Japan though.
View Derek Cohen's profile
Derek Cohen
372 posts in 3966 days
#4 posted 12-30-2017 01:29 PM
Hi Brian
I would use a differently sharpening strategy. It would be interesting if you tried it, and then reported back.
Firstly, hollow grind the bevel with your wet grinder to the edge of the blade.
Now you have a choice of freehanding the blade on flat on the hollow (which is what I do) or using a honing guide to create a small secondary bevel. If you freehand, the angle for the hollow grind should be the final bevel angle.
Which ever method you prefer, you will not need more that 3 strokes with the Fine diamond stone to raise a wire edge. If you ground to the very edge of the blade with the Grizzly, you could even start with the 4000 Norton.
The last step is to hone with the 8000 grit, again a few strokes are all that is needed to polish away the scratches of the 4000. Remember to polish the back of the blade with the 8000 (only). A strop (green compound on MDF) is also useful to ensure the wire is gone.
Keep the coarse DMT for flattening the Nortons. Use the Fine DMT in place of a 1000 waterstone to start. Keep the 4000/8000 Nortons. Ditch the rest.
I place an emphasis on creating a hollow grind as the foundation for all that follows.This may interest you: http://www.inthewoodshop.com/WoodworkTechniques/UltimateGrindingSharpeningSetUp.html
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
View Manitario's profile
Manitario
2630 posts in 2881 days
#5 posted 12-30-2017 06:11 PM
I’ve used a bunch of different sharpening setups too and took a couple years to find something that I like ie. consistent and easy. Have a Tormek, gives great results but takes too much time. Used diamond stones for awhile too, and still have the coarse stone set up for the occasional edge that is chipped. Otherwise I just use 3 waterstones:
https://www.lie-nielsen.com/product/blade-sharpening/blade-sharpening-ohishi-waterstones-?node=4203
They just need a spritz of water before using so are always ready to go, without the mess of soaking, and I find that they’re quicker and give a finer edge compared to the diamond stones. I have 1000/4000/8000 grit. Unless I’ve been really hard on a blade and taken too long b/t sharpenings, most blades I can sharpen with this setup in under a minute.
View tacky68's profile
tacky68
70 posts in 1425 days
#6 posted 12-31-2017 04:10 AM
I have the full line-up of DMT Dia sharp(220-8000g). Six total plates. I do not get a mirror polish on the back.
My chisels are sharp, but not like I thought/hoped, even with a strop. I often do not get a wire edge either, but have been able to shave arm hair. Thought is was me not doing something right. Maybe I will look into some LN stones
(thanks Manitario), they are less expensive than the DMT’s.
Tim.
View HorizontalMike's profile
HorizontalMike
7757 posts in 2912 days
#7 posted 12-31-2017 11:53 AM
I built this and it made my tools much easier to sharpen:
http://lumberjocks.com/reviews/3179
Now, the only thing I use stones for is to sharpen my pocket knife. All of my lathe tools and my plane blades only take seconds with the above sharpening system. As a result, I sharpen them more frquently and keep tham much sharper in use. Just my 2-cents…
bbasiaga
#8 posted 01-02-2018 09:25 PM
Thanks for all the input. I was reading around again and figured out my diamond ‘fine’ stone is more like 600 grit than 1k. So I’ve been making a bigger jump there than I thought. I suppose it depends on which charts…It may be closer to 800. Either way, may explain why it always seemed to take more than 10 strokes to polish up like people always say.
I may look at the Ohishi 1k/8k combo, or separate 1k and 8k shaptons….something I will use more because it is less of a hassle. If I had a sink in the garage it would be a non issue…but that is way more expensive than new Stones!
View ColonelTravis's profile (online now)
ColonelTravis
1770 posts in 1892 days
#9 posted 01-02-2018 10:42 PM
For chisels and planes, I’ve used a 1k Shapton pro and a 8K Japanese polisher and that’s it – razor sharp every time. No need to have too many steps.
bbasiaga
#10 posted 01-03-2018 03:22 AM
Col. Travis,
I’ve basically been going 600 straight to 8k so far. It works ok too. I just wonder if I’d see some benefit to going up to 1k then to 8 k?
Brian
View msinc's profile
msinc
382 posts in 502 days
#11 posted 01-03-2018 03:38 AM
I think I would stick with what you have…it’s working and it’s paid for. I mean, how often do you get it all out and sharpen with it? The way I see it, the money you spend {I get that you have the money} on upgrading for convenience could be going to {just for example} more/different shaper bits…or some other tool that could increase your capabilities. A better sharpening system might be nice and might save a little time, but it wont let you do more/different things. Now, if what you had just was not working that would be different, but it sounds like it does the job. Spend the cabbage on something that will increase your capabilities, not just make an “unliked” job a little easier. Just my opinion, take it for what it’s worth.
ColonelTravis
#12 posted 01-03-2018 04:53 PM
I doubt if there would be a benefit moving from 600 to 1K in and of itself – but there could be an improvement because of the change of stone. I’ve got a very coarse DMT diamond stone that I use, primarily, to flatten my waterstones. I’ll use it to flatten the back of a brand new blade also. I prefer the way the waterstones cut vs. diamond. Just my preference, I haven’t tried other diamond stones, so I don’t know how fast they work compared to waterstones, which are fast sharpeners (that’s why I use them over oil and diamond.)
Also, I couldn’t tell you if my 8K stone cut like a true (whatever that is) 8K stone or a 10K stone of some other brand. There are so many brands out there, and they vary. My Shapton Pro 1K works better than the King 1K I had when starting out.
Derek Cohen
#13 posted 01-03-2018 09:06 PM
Col. Travis,
I ve basically been going 600 straight to 8k so far. It works ok too. I just wonder if I d see some benefit to going up to 1k then to 8 k?
Brian
- bbasiaga
Brian, different stones are not going to get you sharper. Only a better technique will.
Stick with the King 1000, and Norton 4000/8000. That is all you need. Diamond stones are poor substitutes for waterstones. The grit in the diamond stones leaves deeper scratches, and these make it more difficult to move up to a higher grit.
Do not change your stones – at this time anyway. There is no magic bullet in a substitute stone. You need to make your stones work first – others have, so you know it is not the stones. Read my earlier post for tips on technique.
Regards from Perth
Derek
bbasiaga
#14 posted 01-04-2018 03:16 AM
Derek, thanks for all the advice. Just to be clear, I’m getting acceptably sharp with what I have, Its just a pain because I don’t have a sink in the garage (Shop). So i have to haul stuff inside to do the sharpening. If I went with stones that don’t have to be soaked, I could use them outside in the garage with little fuss. That is what started this whole thread – getting an 8k shapton or ohishi stone does that for me, as I could use it in combination with my fine diamond.
Kind of got on a tangent with the 600 vs. 1k to 8k transition there.
Brian
View AlaskaGuy's profile
AlaskaGuy
4135 posts in 2307 days
#15 posted 01-04-2018 05:53 AM
I ve used a bunch of different sharpening setups too and took a couple years to find something that I like ie. consistent and easy. Have a Tormek, gives great results but takes too much time. Used diamond stones for awhile too, and still have the coarse stone set up for the occasional edge that is chipped. Otherwise I just use 3 waterstones:
They just need a spritz of water before using so are always ready to go, without the mess of soaking, and I find that they re quicker and give a finer edge compared to the diamond stones. I have 1000/4000/8000 grit. Unless I ve been really hard on a blade and taken too long b/t sharpenings, most blades I can sharpen with this setup in under a minute.
- Manitario
Across the table from your 3 stones are 3 rectangular objects. Are those diamond plates for flatting the stone? If so why 3, or maybe they are something else.
