Using Cross-cut Sled
Forum topic by Divotdog posted 03-14-2011 09:18 PM 1443 views 0 times favorited 8 replies Add to Favorites Watch
View Divotdog's profile
Divotdog
68 posts in 3464 days
03-14-2011 09:18 PM
Hi All
I am gaining a little experience but need help with a sled I made for cross cuts. I have been working with small pieces but now I am building a bookcase and the pieces are too long to use a stop for equal length cuts.
What is the best way to make sure my cuts are uniform?
Thx,
Dog
-- David, Dallas,Tx - golf weather is warming up but it's cool in the shop.
8 replies so far
Divotdog
#1 posted 03-14-2011 09:34 PM
OK I think I see how – bring the end over to the fence then back off the fence and try to keep th piece in place.
View BreakingBoardom's profile
BreakingBoardom
615 posts in 3103 days
#2 posted 03-14-2011 10:12 PM
If I understand what you’re asking, I would clamp a block to your fence and set your fence at your desired length plus the thickness of the block. Then set the piece to be cut up against the block and secure it in place and cut. You don’t want your piece riding along the fence the whole time cause it could get caught and bind and possibly kickback. Hope this helps.
-- Matt - http://breakingboardom.wordpress.com/
View NBeener's profile
NBeener
4816 posts in 3195 days
#3 posted 03-14-2011 10:14 PM
For LENGTH, I totally agree with Matt: stop blocks.
If you’re wondering how to get it SQUARE, though … well … that’s the purpose of a well-designed, well-built, and properly squared crosscut sled, in the first place.
Step one IS ensuring that YOUR fence (the back fence) IS perpendicular to the blade.
Did you do that, already, on yours ?
-- -- Neil
View richgreer's profile
richgreer
4541 posts in 3096 days
#4 posted 03-14-2011 10:28 PM
I suspect that the boards you are working with are going to be too long for the fence based ideas suggested above.
Personally, I would rig up a way to get a stop block out to the end of the board with a temporary extension attached to your sled. Make an L-shaped piece of wood and screw the long piece to the sled in front of your stock.
In many applications it is not essential that the board be exactly X inches long to the 1/1000 of an inch but it is essential that all the boards be of exactly the same length. You need a good stop to do that.
View Broglea's profile
Broglea
685 posts in 3112 days
#5 posted 03-14-2011 10:43 PM
You may even try to tape or clamp a stack of boards together and use a circular saw to cut them all at once. Clamp a carpenter’s square to the boards and run the saw along the square. If you are using dados to secure the shelves it would hide any tear out.
Divotdog
#6 posted 03-14-2011 10:51 PM
Thx guys – yeah the problem is boards longer than sled so it looks like screwing on a temp ext is best.
Great help – might not have thunk it up – better at golf, good thing (:>
View rbterhune's profile
rbterhune
176 posts in 3243 days
#7 posted 03-15-2011 09:20 PM
Trim both pieces to a rough length using a circ saw…maybe an 8th heavy, or less. Put one on the table saw to clean it up (fence removed) to exact length, then clamp the two boards together and use a router to flush trim the second board.
View OutPutter's profile
OutPutter
1199 posts in 4012 days
#8 posted 03-21-2011 02:47 AM
Sounds crude but in the past I’ve stacked something heavy at the proper distance to the saw blade and used it as a stop. Just don’t bang the boards up against it and it shouldn’t move. I’ve used bricks on a cooler for example.
-- Jim
