Craftsman Pro 315 Table Saw Noise
Forum topic by Lrobinson posted 12-29-2017 12:31 AM 635 views 0 times favorited 5 replies Add to Favorites Watch
View Lrobinson's profile
Lrobinson
6 posts in 643 days
12-29-2017 12:31 AM
Topic tags/keywords: table saw noise squealing pulley belt contractor belt driven table saw craftsman noise
I’ve searched the internet for a possible explanation of the noise my table saw is making. I can’t describe it, so I’ve made 3 videos. As I was trying to fix the noise, I ended up just doing a total tuneup of the saw (or at least a tune up of everything I was capable of tuning up) So, it’s all square, the pulley’s are aligned, new belt, etc. I also took an air compressor and blew out the motor. The following videos demonstrate the noise I’m talking about. It’s a clicking sound when you just turn the motor pulley by hand, but when the saw is on, its a SCREAMING sound.
1. While the motor is off: https://youtu.be/x_Bol7CgUzg
2. While the motor is on: https://youtu.be/buKlV922gvM
3. Powering down: https://youtu.be/LfJpMEsb07w
Any help/suggestions would be greatly appreciated
5 replies so far
View Tennessee's profile
Tennessee
2893 posts in 2720 days
#1 posted 12-29-2017 01:02 AM
Well, to my ear, it is definitely metal on metal.
Either in a bearing, or a shim, something is rubbing.
I’d look for spacing on that shaft, from the pully right through to the end of the shaft.
Something is rubbing.
Since it does spin, and seems to spin fairly effortlessly, it seems like something is just a hair out of alignment.
View wichman3's profile
wichman3
76 posts in 826 days
#2 posted 12-29-2017 01:23 AM
Trying running the motor with the lights out, is there arcing going on.
Use a mechanics stethoscope (or a 4 ft dowel) to isolate each bearing.
Use a penetrating spray oil on each bearing, one at a time to isolate.
MrUnix
7053 posts in 2404 days
#3 posted 12-29-2017 01:37 AM
Open up the motor… sounds like bad bearings to me. You can verify once you crack it open. That is if it has ball bearings. If it’s sleeve bearings, when was the last time you oiled them?
Lrobinson
6 posts in 643 days
#4 posted 12-29-2017 02:39 PM
I may try to open up motor today. I’ve never done anything that extensive before so wish me luck.
wichman3
#5 posted 12-29-2017 05:08 PM
I may try to open up motor today. I ve never done anything that extensive before so wish me luck.
- Lrobinson
Take pictures as you go and make alignment marks on parts as well.
Good luck :) (you Can do this)
