Searching for blades for a unique Marples bow saw
« back to Hand Tools forum
Forum topic by TheMadCarpenter posted 12-28-2017 06:26 PM 1377 views 0 times favorited 8 replies Add to Favorites Watch
View TheMadCarpenter's profile
33 posts in 836 days
12-28-2017 06:26 PM
Topic tags/keywords: question bow saw traditional
I bought a nice bow saw from Ed’s tool store when I was in a class at The Woodwrights school in November. It is marked only with the following (in the middle of the uprights):
The saw is 11” across and 10” tall. The blade is 8” long, 1/8” tall, and has 5 1/2” of teeth. The saw has 2 pins holding the blade in place that are 1/16” each
Does anybody know of a source for the blades and replacement pins? Any idea of the aproximate age?
Thanks in advance
8 replies so far
View Bluepine38's profile
3379 posts in 3017 days
#1 posted 01-01-2018 01:54 AM
Sounds similar to an 8” coping saw blade sold by Menards and others, you could check that out.
View waho6o9's profile
8130 posts in 2508 days
#2 posted 01-01-2018 02:17 AM
Maybe send them an email and hopefully you’ll get what you need. Good luck now
View bilyo's profile
145 posts in 1034 days
#3 posted 01-01-2018 02:19 PM
It seems to me that you should be able to make blades from band saw blade stock. I’m not sure how you would insert and fasten the pins at either end, but I think I read something about that a long time ago. An internet search might turn something up, if you are so inclined.
#4 posted 01-09-2018 01:36 AM
I tried the search for 8” blades at menards and if you zoom in on the pic, it shows 6” blades. Searcing the sku number also shows 6” blades. I’ve talked to the staff at tools for working wood, they couldn’t help.
I will be cutting some 1/8” bandsaw blades, as I think that will be my best bet. I just need to figure out the best way to drill a 1/16” hole in the ends so I can insert pins for holding
Excellent information from all
Thank you
View Alex Lane's profile
Alex Lane
481 posts in 3822 days
#5 posted 01-09-2018 04:00 AM
I’d imagine the advice to use bandsaw blade stock is good. Drill holes sized for a couple tiny spring pins (aka roll pins) and you should be in business. Have fun!
-- Lane Custom Guitars and Basses
#6 posted 01-09-2018 04:42 AM
10086 posts in 3579 days
#7 posted 01-09-2018 04:44 AM
I’ve tried band saw blade stock in a bow saw
and found the tooth hook too aggressive for
sawing by hand.
View LesB's profile
1607 posts in 3375 days
#8 posted 01-22-2018 06:10 PM
Have you tried buying a longer blade, cutting it to proper length. Then heat just the ends with a torch to remove the temper so you can drill the holes and if you think it if necessary re-temper them.
Also my local saw sharpening shop makes up bandsaw blades to any length (my band saw takes a unique size) and they have rolls of blade material. They might even be able to punch the holes for you.
I have preformed a similar de-tempering procedure with worn out reciprocating saw blades to bend them to make right angled cutting blades (for removing window panes) and other purposes.
-- Les B, Oregon
