Repairing warped barn door
Forum topic by Mark posted 12-28-2017 02:39 AM 5155 views 0 times favorited 31 replies Add to Favorites Watch
View Mark's profile
Mark
40 posts in 478 days
12-28-2017 02:39 AM
Hi all,
I built a 60” x 98” barn door for a customer and have been notified that it has warped. From the photo she sent me it looks as though one corner is about an 3/4” to 1” out of whack.. the bottom left corner bending away from the wall.
It was constructed out of 2×8 doug fir, decorative diagonal brace from one corner to another, with pine t&g in dadoes around the frame.
I know that some type of turnbuckle is what I’m looking for, but you can see that I don’t have much clearance. Can anyone make a suggestion of something low profile and yet strong enough to pull the corner in on this 1 1/2” door?
Edit-
This seems like a decent solution, with large enough screws for the force, but the cable isn’t long enough.
Do you think just buying a long enough cable would suffice? Should I go up in diameter?
31 replies so far
View Loren's profile
10477 posts in 3849 days
#1 posted 12-28-2017 02:49 AM
I’d say 3/4” is within acceptable tolerances
considering the size of the door and quality
of material.
That said, since you didn’t manage customer
expectations from the beginning…
I’m aware of turnbuckle kits to remove sag
from gates but I can’t think of a way to
remove “potato chip” from a door with one.
View Mark's profile
Mark
#2 posted 12-28-2017 02:54 AM
Would the tension not pull it back in, if installed on the back?
View John Smith's profile
John Smith
1482 posts in 364 days
#3 posted 12-28-2017 02:56 AM
wondering: how long has it been in the customers home ?
how long was the wood actually “in” your shop.
what were the climatic conditions of your shop when you assembled it.
I am thinking along the lines of temperature and humidity changes between
your shop and the clients home.
a quick fix now may cause more problems later when the wood finally
comes to its acclimated resting place.
if it were me – I would ask the client for patience until you can be assured
that the wood is fully acclimated – then explore your options of correction.
also wondering: what kind of finish did you put on the wood and how many coats ?
and the back side? equal treatment as the front ??
jus my Dos Centavos
-- I started out with nothing in life ~ and still have most of it left.
View Mark's profile
Mark
#4 posted 12-28-2017 03:05 AM
It has been in the client’s home about 2 months. My shop was temp/humidity unregulated, but it was in the fall, so it should have been outside of any extremes. Time the lumber spent in my shop, probably about 3 weeks.
Client’s is a home builder and the house was incomplete, so again unregulated air/temps. Probably drier conditions now than to begin with.
Equal treatment on both sides, 5 coats of GF High Performance.
#5 posted 12-28-2017 03:07 AM
I think these are designed to do it.
I’m not sure about the diagonal approach. Perhaps
you are correct.
#6 posted 12-28-2017 03:29 AM
I got curious. Perhaps going corner-to-corner
is the wrong approach.
Video shows a way to pull in one corner with
a threaded rod. https://youtu.be/Db5TiyyXeIY
John Smith
#7 posted 12-28-2017 03:34 AM
I think that when all the votes are in, you will have to bring it back to your shop for corrective action.
I did a quick google search on why doug fir warps, cups, splits, etc. and the general consensus is that
Acclimatization is essential. also alternating the grain pattern. (as with all large wood panels).
a real bummer as I am sure that bad boy is HEAVY !!!
I am just assuming that the door is strictly cosmetic and not an actual working door to another room?
if you can install any of the above mentioned hardware in the back for corrective action, I would do whatever
it took to make it as quick as possible between the clients home and in your shop and back again to prevent
or at least minimize any further issues with acclimation after you take it back. Unless you can do it “on site”. there are more aggressive measures that can be taken such as making deep saw kerfs in the back.
but that is to the extreme end of the spectrum.
heartbreaking I’m sure.
View Mark's profile
Mark
#8 posted 12-28-2017 04:09 AM
Sadly, “on site” is 3 hours away. I’m going to order the hardware so she can have one of her contractors do the install, and hope that does it.
I built that one and another at the same time, the other is doing just fine. They both are functional and slide in front of a laundry room. At least it’ll never be closed with someone on the inside, so fitting something on the rear face will never actually be seen.
John Smith
#9 posted 12-28-2017 04:15 AM
all in all – GREAT JOB in your craftsmanship !!!!!
117328 posts in 3778 days
#10 posted 12-28-2017 01:57 PM
It’s possible your joinery is not allowing wood movement creating the warp,or you built this with construction grade material that wasn’t dry enough to get a stable product. I think in using turnbuckles and cable or a threaded rod the customers might get their hands or clothes snagged on it.
#11 posted 12-28-2017 02:09 PM
It might be hard to do given the size of the door but Charles Neil has a trick where you cut a very deep kerf(70% of it’s width) on the edge of the stiles of the door and glue with Urea-formaldehyde and clamp flat until dry. This has worked great for cabinet size doors for me.
View dhazelton's profile
dhazelton
2793 posts in 2498 days
#12 posted 12-28-2017 02:09 PM
Now it’s winter and she has the heat cranked. I’d ask if she can live with it until the spring and see what the door does. You may correct something that will correct itself. I also believe that anything you put on the back may damage the drywall when the door is opened.
View jbay's profile
jbay
2879 posts in 1100 days
#13 posted 12-28-2017 02:25 PM
1 1/2” x 1 1/2” x 1/4” Angle iron down both sides.
or a C-Channel, (if you could find the correct size)
you could put it on all 4 sides to maintain the look like it was planned.
View JBrow's profile
JBrow
1366 posts in 1121 days
#14 posted 12-28-2017 02:55 PM
GuntherBespoke,
I see a number of problems with your (OP) proposed solution. It is difficult to understand how the sliding door would function with a cable and turnbuckle attached on the wall side of the door. It would seem the hardware could scrap the wall as the door is opened and closed. I am also doubtful that enough force can be applied to overcome the bow in the stile and/or rail. Additionally, even if the turnbuckle and cable work, the hardware would be applying a fair amount of force to the entire door and could result in a failure elsewhere. As a customer, I would be unhappy to see an ugly add-on afterthought applied to my custom door. And then to have to install corrective hardware myself would be a put-off plus, if installed incorrectly, it could make matters worse.
Without seeing the door, this suggestion is a guess. From the photo it appears the left stile may have bowed, although the bottom rail may be the problem. If the bottom rail and left stile are replaced, the door may return to true. It would require some time and the finish on the new rail and stile would have to be matched, but in the end I would think that this approach to the repair would enhance your reputation with a customer who is a builder and thus could be the source of additional business.
View clin's profile
clin
956 posts in 1197 days
#15 posted 12-28-2017 07:54 PM
Another vote that apparently using construction grade wood, that hadn’t dried to indoor levels before being built, is the source of the problem.
I like this idea from Loren. Looks to be similar to the tension rod in a guitar neck. But I think jbay’s idea of wrapping with steel channel may be your best bet, but a heavy door would get a lot heavier doing that.
No matter what, that wood wants to move, and anything you do to force it straight runs the risk of creating forces that will cause splits and cracks later. Might be better to suck it up and remake with properly dried wood.
I m not sure about the diagonal approach. Perhaps
you are correct.
- Loren
-- Clin
showing 1 through 15 of 31 replies
