Is this salvageable - cypress tree cookie. Project reno?
Forum topic by Upgrayedd posted 12-27-2017 11:42 PM 541 views 0 times favorited 11 replies Add to Favorites Watch
View Upgrayedd's profile
Upgrayedd
94 posts in 1303 days
12-27-2017 11:42 PM
So my Dad got this clock somewhere 10 years ago, so it’s fairly old, and free to him and me of course. It looks like a paper drawing of a deer was glued to cypress cookie, then epoxy covered all. Neither of us like it, and was thinking on what it could be turned into?
It’s a 25” x 29” cypress tree from Louisiana, at 1 1/2” thick.
Problem is due to insertion of the clock, this big section is cut out leaving me only 1/4” of wood there.
Initially thought it could be a table… LJ Table
I’m considering using a “router sled for planing” and having a go at refinishing, but I’m running short of real estate due to hole in back, so I’m not sure what I can do?
Is this worth the effort? Or is there another use for this piece of wood that anyone can see?
-- Upgrayedd - spelled thusly, with two Ds, for a double dose of this pimping.
11 replies so far
View TheFridge's profile
TheFridge
10129 posts in 1606 days
#1 posted 12-28-2017 12:11 AM
Table sounds awesome. I’d probably turn or make a dowel to plug the holes and use the side with the small hole.
A router sled would work. Unless it came out perfect I’d probably go over it with a low angle block plane.
Upgrayedd gonna get his money.
View Jack Lewis's profile
Jack Lewis
320 posts in 1199 days
#2 posted 12-28-2017 12:35 AM
Make a clock-table. One of a kind, Heehee
-- "PLUMBER'S BUTT! Get over it, everybody has one"
Upgrayedd
#3 posted 12-28-2017 12:40 AM
The 2nd picture shows hole, it’s 5” diameter… problem. That’s the biggest limiting factor. Plus effectiveness on routing away the epoxy?
Thanks for help!
Upgrayedd
#4 posted 12-28-2017 12:51 AM
Clock table sounds awesome… just add 2×4s.
TheFridge
#5 posted 12-28-2017 01:34 AM
Use your router to route a true circle in the cookie and use a bandsaw or circle cutter of some sort to cut some cypress to fit.
Don’t know til you try but I’m guessing it’ll probably work.
Upgrayedd
#6 posted 12-28-2017 02:17 AM
Interesting idea Fridge, it could definitely work. Actually could be any shape insert to fill that section. It would be different.
TheFridge
#7 posted 12-28-2017 03:18 AM
Yep. I was thinking of a gap filler for the bottom side but it could be an accent as well. Maybe.
Maybe a built in beer holder :)
View AZWoody's profile
AZWoody
1396 posts in 1344 days
#8 posted 12-28-2017 03:29 AM
The first picture looks like it’s giving us the “finger”...
Upgrayedd
#9 posted 12-28-2017 04:23 AM
Indeed it does, with a 6 finger hand. I thought the same thing. One reason it should not be a clock
View wood2woodknot's profile
wood2woodknot
95 posts in 2094 days
#10 posted 12-28-2017 04:56 AM
Epoxy the underside and use the hole for a cup/glass holder. Who else would have a table top with a built in coaster/cup holder? a chip dip reservoir? the kitty for the poker ante? even a flower pot holder?
Who knows you could be the start of a new fad. And it looks a lot nicer than those log lawn chairs.
Just funnin’. Have fun and don’t hold back. And let us see what you end up with.
-- ajh
View tmasondarnell's profile
tmasondarnell
97 posts in 1910 days
#11 posted 12-28-2017 04:49 PM
The first picture looks like it s giving us the “finger”...
- AZWoody
I feel better about myself now that I know that I am not the only one who had that same response.
