Delta 36-725 Contractor Table Saw discharge shoot fixes
Forum topic by Wildvortex posted 12-27-2017 11:15 PM 1755 views 0 times favorited 12 replies Add to Favorites Watch
View Wildvortex's profile
Wildvortex
43 posts in 845 days
12-27-2017 11:15 PM
Topic tags/keywords: tablesaw
I have been using this saw for about a year now maybe more. The other day I noticed a new scraping sound and found that the weight of my dust collector tube had caused a plastic pin to break allowing the metal of the chute to scrape on the blade.
Have any of you also had this problem and what has been your fix?
-- Use caution, slow down, and use the tool properly...the ER would love to have your money...don't give it to them.
12 replies so far
View WhyMe's profile
WhyMe
1074 posts in 1765 days
#1 posted 12-28-2017 12:06 AM
I removed the whole stock dust collection shroud and added a 4” dust collection shroud to the bottom. I didn’t do it because of anything breaking.
Wildvortex
#2 posted 12-30-2017 12:45 PM
Do you know where I can find such a shroud?
WhyMe
#3 posted 12-30-2017 02:36 PM
I had to custom make it. Here’s a post where it’s shown.
http://lumberjocks.com/topics/128674
Wildvortex
#4 posted 12-30-2017 05:39 PM
Ah yes, I see. Makes perfect sense now. My first thought was also to make it more funnel shaped. Great thought and thanks. See that as being much cheaper than buying something. Seen a product very similar premade but much more expensive than a few scraps of plywood.
View aravenel's profile
aravenel
20 posts in 387 days
#5 posted 01-01-2018 02:10 PM
Yes, the same happened to me. I took the back panel off and zip tied the chute back up to get it off the blade. Long term I plan to make a dust mod as described and get rid of the chute altogether.
Really been the only issue I’ve had with the saw, been very good to me otherwise.
View WhiteCollarMill's profile
WhiteCollarMill
1 post in 277 days
#6 posted 03-14-2018 07:59 PM
I had the same problem. Very furstrating and cheaply built part of the saw….However, like said above it’s my only complaint with the saw
View Tola's profile
Tola
3 posts in 267 days
#7 posted 03-24-2018 12:05 PM
I just bought the saw and I am having difficulty removing the shroud. I took the back panel off, and was able to access the 2 screws near the table but I think there is a flat head hex screw at the bottom of the shroud that is only accessible from the inside and it is challenging to see and I can’t really get my hand in there to loosen it. For those of you who removed the shroud, any tricks? Am I missing something. WhyMe, nice job on the modification. I intend to do something similar, probably with a funnel shaped chute under the saw.
WhyMe
#8 posted 03-24-2018 12:36 PM
Trying to remember but I think I tilted the motor head to 45deg to get at that one screw. I’ll take a look at the saw later to see if I can refresh my memory.
View Tola's profile
Tola
3 posts in 267 days
#9 posted 03-24-2018 12:51 PM
Hah! Solved my own problem. Raised the motor up to the top, which gave me access to the hole in the frame the shroud is attached to. The small phillips head on the allen wrench that comes with the saw is perfect for undoing the screw that is holding the shroud in place.
View Tola's profile
Tola
3 posts in 267 days
#10 posted 03-24-2018 10:36 PM
Thanks for your reply, WhyMe. I think I posted just about the same time that you did.
WhyMe
#11 posted 03-25-2018 12:05 AM
- Tola
Sorry I’ve been really busy and didn’t get to look at my saw. Glad you figured it out. I knew the screw could be gotten to but just didn’t remember how.
View Grrrrandpa's profile
Grrrrandpa
1 post in 85 days
#12 posted 09-23-2018 12:10 AM
Thanks for the info. I ended up here because my dust chute got bent. I didn’t know it was bent, but I did know when I started my dado set, sparks came flying out of the blade slot. I removed the chute … in my bersion of the Delta 36-725, it was held on by only two screws, one accessed through the top and one accessed through the removed back plate. The metal was curled over and the chute was distorted out of shape. Since a new one costs about $70 bucks, I’ll forgo that “pleasure”.
I’ve owned one Delta Unisaw and five Delta Contractor saws in my long stint at woodworking. I was reluctant to purchase a new one as the old ones were really tried and true. However, after I looked over the 735 at Lowes, I couldn’t resist. After two years, I’m happy with my purchase, with the exception of this dang dust chute.
I’m currently working to finish a honey-do project, so I’ll operate without dust collection, but will be making a dust port similar to WhyMe’s solution as soon as I finish my current project.
Thanks again for the info!
Grrrrandpa
