How to create this compound curve
Forum topic by JoelB posted 03-14-2011 04:57 AM 1186 views 1 time favorited 3 replies Add to Favorites Watch
View JoelB's profile
18 posts in 3307 days
03-14-2011 04:57 AM
How would you go about creating one of the arms in the star pattern on this piece? I am thinking about trying to duplicate this for my self and would like your input. I am thinking about building an angled platform to place the piece at an ange on the RAS and then turn the head on the RAS 90 degrees and tilt it too and then pull it through the workpiece. Seems like a lot of trial and error to get the angles right. I plan on making one and then making a mold of it and duplicating it via the mold.
Would love input on this.
Here it is:
3 replies so far
View Loren's profile
10105 posts in 3582 days
#1 posted 03-14-2011 05:23 AM
If you know how to work with molds, carve it out of a soft material. I
wouldn’t bother trying to figure out how to machine it from wood.
From the look of it the curves may be sheet metal.
18227 posts in 3610 days
#2 posted 03-14-2011 05:50 AM
The star patterns are intersecting sine waves. Not quite sure how you are thinking of cutting them.
View Dandog's profile
250 posts in 2709 days
#3 posted 03-14-2011 05:54 AM
well I would start by making my stock round, build a jig to put it on the table saw. rip cut it into the half-round. Then you just have to sand it or cut on the lathe with the depth stop that matches the contour of the half-round or little less.slap it back, tablesaw with a stop. Crosscut. Put it back, lathe, Do the contour on the lathe then back to the tablesaw crosscut repeat.that would take some serious time. You to find a way to make the contours all the same with the stop that hardest part. You figure that out you got it licked. Metal lathes have a Quill on the opposite end of the chuck. Set the depth stop, you got it.I take check and MasterCard. ;-)
you have to lay out equal increments on the bed of lathe. then you move the quill forward to the thickness of the piece. On the quill should look like the contour. The half-moon shape will develop as that’s cut out.
-- life an woodworking is one big experiment
