Magnetic starter
Forum topic by MrRon posted 12-27-2017 05:29 PM 369 views 0 times favorited 6 replies Add to Favorites Watch
View MrRon's profile
MrRon
4992 posts in 3364 days
12-27-2017 05:29 PM
Topic tags/keywords: question
Are there any magnetic starters available in 110 volts, similar to the magnetic starters on 220 volt?
MrUnix
6891 posts in 2319 days
#1 posted 12-27-2017 05:52 PM
Sure.. any voltage you want… 110 (115/120), 200 (208), 230 (240), 400, 460, etc… Most will have multiple taps on the control transformer to select whatever input voltage you have. Here is one such animal where you can see how the transformer can be hooked up for different voltages:
View Fresch's profile
Fresch
302 posts in 2041 days
#2 posted 12-27-2017 06:12 PM
What are you starting?
View AZWoody's profile
AZWoody
1396 posts in 1344 days
#3 posted 12-27-2017 06:26 PM
MrRon
#4 posted 12-28-2017 05:03 PM
I have a magnetic starter on my 3 hp saw. I know it is a safety issue so I thought it would be a good idea to put them on all my power tools, bu after seeing the prices, I don’t think so.
MrUnix
#5 posted 12-28-2017 05:25 PM
Don’t confuse a starter with a simple magnetic switch. A starter, be it a NEMA type like the one I pictured, or an IEC type like Woody pointed to, provides overload protection as well. If the motor you want to control already has overload protection, then you can get by with just a simple magnetic type switch that doesn’t provide any overload capabilities. Those can be had for around $20.
View TheFridge's profile
TheFridge
10129 posts in 1606 days
#6 posted 12-28-2017 05:40 PM
Meh. I’d say yes maybe in a production environment but no where near as much in a home shop.
If you wanted to put together a enclosure with contactor and push buttons you could probably do it for 30$ apiece.
