Any plans out there for a router keyhole jig?
Forum topic by kanihoncho posted 03-13-2011 07:13 PM 10138 views 0 times favorited 6 replies Add to Favorites Watch
View kanihoncho's profile
kanihoncho
56 posts in 3073 days
03-13-2011 07:13 PM
Topic tags/keywords: jigs router keyhole
I am thinking about getting a keyhole router bit. Does anyone have a jig for it’s use? I’ll be searching the web. I prefer to build over buy if possible. Many thanks.
View ChunkyC's profile
ChunkyC
856 posts in 3254 days
#1 posted 03-13-2011 07:24 PM
Mine is just a piece of 1/4 HB with a slot cut in the center. I have an adjustable fence on one side that registers it to the side. Nothing fancy but it works great. I’d take a picture but I have no idea where it is at the moment. I haven’t seen it in a long time. :(
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
View bobsmyuncle's profile
bobsmyuncle
110 posts in 2691 days
#2 posted 03-16-2011 04:54 AM
Here’s one for $2
http://www.woodstore.net/kerojigpl.html
If you look real close, you can probably figure it out.
View William's profile
William
9949 posts in 2842 days
#3 posted 03-16-2011 01:45 PM
Go here. Scroll down on the menu at the left side of the page. Look in the section labeled “Shop Tips” for “Routing Keyhole Slots”. It give a quick and easy way to make a jig.
View stnich's profile
stnich
118 posts in 2924 days
#4 posted 03-16-2011 01:57 PM
I use key hole slot all the time and don’t use a jig. I pre drill a slightly larger hole than the keyhole bit and then just free hand the cut. Depending on what I’m doing I sometimes need to make a reference line on the work piece so I know when to stop. The bit can wander a little if you’re not careful, so take your time and just hold the router firmly. A lot of the things that I’m routing are curved which can make it more difficult to make a jig.
View woody57's profile
woody57
650 posts in 3427 days
#5 posted 03-16-2011 03:02 PM
William showed you a good one. I made one very similar for a trim router and it works great.
-- Emmett, from Georgia
View richgreer's profile
richgreer
4541 posts in 3074 days
#6 posted 03-16-2011 03:16 PM
My “jig” is a single piece of wood that I clamp to the side of where the router will set. It’s only purpose is to help me cut a straight line. It’s probably not necessary, but it makes me feel a little more secure.
