Shellac - I think I love it!
« back to Woodturning forum
Forum topic by Madrona posted 12-26-2017 11:22 PM 985 views 0 times favorited 17 replies Add to Favorites Watch
View Madrona's profile
Madrona
108 posts in 977 days
12-26-2017 11:22 PM
Topic tags/keywords: alder bowl bowl turning shellac lathe
I’ve been using Zinsser Seal Coat as a sanding sealer for years and it does a great job. Recently I started using their Bulls Eye Shellac as a final finish. It is easy to apply, dries in about an hour, easy to sand and re-coat and leaves a really nice sheen. I think it may be my new finish of choice.
I’ve made a new video where I turned a piece of Alder firewood into a nice little bowl and applied this finish. Take a look and let me know how you feel about shellac.
https://www.youtube.com/watch?v=1MRgEQGeRcA
-- Living In The Woods Of Beautiful Bonney Lake, Washington
17 replies so far
View shipwright's profile
shipwright
8031 posts in 2880 days
#1 posted 12-26-2017 11:27 PM
French polish is my go to finish so …. I like it.
View TheFridge's profile
TheFridge
9856 posts in 1568 days
#2 posted 12-27-2017 01:04 AM
Nicely done.
Shellac is my go to. Very easy to apply and forgiving. I like French polishing a lot myself.
I like mixing my own though. Blonde and garnet.
View SouthpawCA's profile
SouthpawCA
270 posts in 3315 days
#3 posted 12-27-2017 01:13 AM
Now you should try mixing your own shellac using flakes and denatured alcohol. You get a lot more shellac color options. Shellac has become my only finish … you can get everything from a high gloss piano finish to a satin finish. And the best thing … if you don’t like the high gloss you can buff it down … or up..
-- Don
View sawdustdad's profile
sawdustdad
364 posts in 967 days
#4 posted 12-27-2017 01:26 AM
I love shellac, too. It smells so much better than other solvent based finishes and doesn’t require a respirator! I still use wipe-on poly a lot, and polyurethane varnish for table tops, but most decorative articles get shellacked!
Remember, over time (approaching a century) shellac finishes will darken to the point the wood figure will be obscured, but probably not an issue in our lifetimes. Many of the antiques I’ve worked on that are 150 or more years old, have this issue.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View William Shelley's profile
William Shelley
576 posts in 1551 days
#5 posted 12-27-2017 02:51 AM
I love shellac, too. It smells so much better than other solvent based finishes and doesn t require a respirator! I still use wipe-on poly a lot, and polyurethane varnish for table tops, but most decorative articles get shellacked!
Remember, over time (approaching a century) shellac finishes will darken to the point the wood figure will be obscured, but probably not an issue in our lifetimes. Many of the antiques I ve worked on that are 150 or more years old, have this issue.
- sawdustdad
People spend an incredible amount of time and energy trying to replicate that aged finish, so I don’t see it as a flaw of shellac. An heirloom furniture item evolves over time as it gains character and as it’s materials age.
-- Woodworking from an engineer's perspective
View Gadabout55's profile
Gadabout55
27 posts in 1992 days
#6 posted 12-27-2017 03:26 AM
I’m also a new convert to shellac. What took me so long?
TheFridge
#7 posted 12-27-2017 03:29 AM
I use garnet for that aged look.
View Rich's profile
Rich
3340 posts in 671 days
#8 posted 12-27-2017 05:08 AM
Be careful with heat. About 20 years ago I built a sofa table from quarter sawn cherry and French polished it with countless layers of shellac. It was the most beautiful table I’d done at the time. My ex-wife lit a couple of votive candles in little glass cups and set them on it. When they burned down, the glass got so hot, it melted into the surface. All I could do was break them free, leaving a deep divot with raw wood at the bottom. I repaired it, but it was never the same.
View Aj2's profile
Aj2
1582 posts in 1880 days
#9 posted 12-27-2017 06:46 AM
Madrona you should try using real flakes.The stuff in the can isn’t real shellac .
It’s like comparing real cheese to cheese wiz.
The best shellac finish are many many thin coats barely noticeable. I think many woodworkers are missing out not using shellac. I found it to be very durable for many things I make.
I buy my flake from malcome at the http://www.shellacshack.com/.
-- Aj
View Andre's profile
Andre
1957 posts in 1888 days
#10 posted 12-27-2017 07:31 AM
Pretty well stuck on the French Polish from Lee Valley. Then a little paste wax, let dry and polish. Unless it is for the Grankids, then Varathane!
View LeeMills's profile
LeeMills
568 posts in 1383 days
#11 posted 12-27-2017 02:18 PM
I use shellac for most everything. My items are functional so I do not want a high gloss. Yes I did french polish boxes back in the 80’s. Usually I thin the shellac (1 pt to 2-3 pts DNA) and coat the item. I then start burnishing with 0000 steel wool while wet and keep doing that until I a pleased with the luster. Usually I will then burnish with dry shavings if I want to bring the luster up a little.
For some small items I do like a high shine and use Mylands friction polish (yes shellac) to bring up a piano finish.
View splintergroup's profile
splintergroup
2203 posts in 1304 days
#12 posted 12-27-2017 03:25 PM
The only fault I found with shellac is its durability, especially if it may come into contact with solvents (namely alcohol). Beyond that, it is a very friendly finish to work with. Too bad it has become so freaking expensive!
William Shelley
#13 posted 12-27-2017 04:46 PM
- splintergroup
The expense is probably why it’s not used as much. I was pretty ecstatic to find a pound of ruby shellac flakes (Woodcraft brand) in an unopened container at a thrift store for $1. Sometimes I’ll find quart cans of “expired” premixed shellac (Bullseye brand) at the local Habitat for Humanity Re-Store (secondhand building materials supply store). I always test these cans out, if a thin coat is dry and hard to the touch within an hour, I consider it usable.
5034 posts in 2575 days
#14 posted 12-27-2017 05:38 PM
- splintergroup
That’s pretty much where I’m at. I use shellac a lot, but not if durability is needed, like on table tops and such.
View dbray45's profile
dbray45
3320 posts in 2859 days
#15 posted 12-27-2017 08:29 PM
I enjoy French polishing – but I use several other finishes as well.
-- David in Damascus, MD
