HF Doweling Jig
« back to Joinery forum
Forum topic by bilyo posted 12-26-2017 10:39 PM 412 views 0 times favorited 2 replies Add to Favorites Watch
View bilyo's profile
bilyo
308 posts in 1224 days
12-26-2017 10:39 PM
I don’t do a lot of dowel joinery. However, I recently had a restoration project that required some doweling work. I purchased this doweling jig from Harbor Freight. When I tried to use it, I found that my standard fractional drills fit very tightly in the guides. I finally found a metal cutting bit that would barely work and I was able to finish my job. Although everything regarding this tool refers to fractional sizes, I’m wondering if the guides are actually metric. I have nothing to compare it too. Has anyone had similar experience with this tool.
2 replies so far
View ppg677's profile
ppg677
192 posts in 977 days
#1 posted 12-26-2017 11:01 PM
The guides were fine, but the tool is horrible and doesn’t work. I bought an identical tool, machined with proper tolerances, from Woodcraft for $65.
I suggest returning it while you can. Reviews on Harbor Freight’s website indicate my experience is not isolated
View MrRon's profile
MrRon
4992 posts in 3364 days
#2 posted 12-27-2017 06:25 PM
The positive/negative reviews indicate to me it is a hit or miss proposition buying anything from HF. In defense of HF, I have found a few real gems. It seems when the local name brands get worse, HF seems to look better.
