Bevel a Large Radius
Forum topic by Chris posted 631 days ago 159 views 0 times favorited 4 replies Add to Favorites Watch
View Chris 's profile
Chris
1470 posts in 890 days
631 days ago
The Situation: I will be making a desk top that is 1” x 35” x 50” with a large radius cut on both ends of Padauk
The Problem: How would you cut a bevel on the radius?
The top will be constructed of two pieces of Padauk that are 21” wide and 19” wide respectively and 15’ long and are still 6/4 rough at the moment.
This will eventually be my desk for my home office.
-- Chris
View GaryK's profile
GaryK
9551 posts in 888 days
630 days ago
A router table?
Cut it close and use a table saw with a pivot point?
I would really need to see some pictures of exactly what you are trying to accomplish.
View Nicky's profile
Nicky
82 posts in 991 days
630 days ago
Would not have thought of the table saw for this type of cut…sounds interesting.
I’d use a band saw, with an auxiliary table and a pivot point. But this is a big and heavy top.
An alternative may be to make a base for my router (wedge angle to match the bevel), a straight bit and a pivot point. I’m sure constructing a base is a bit more complex. I’d look for router circle cutting jigs for ideas.
-- Nicky
View Sawdust2's profile
Sawdust2
1188 posts in 987 days
630 days ago
I read this and had to come back.
I think I would use a belt sander to bevel the edge then a RO sander to smooth it out.
I just can’t see a safe or efficient way to use a router or saw to do that, unless you just want a short bevel for which you can find a bit to use in your router, after you have cut the radius.
View BroDave's profile
BroDave
86 posts in 713 days
630 days ago
If it were me, I would cut the radius on the band saw and rout the edges.
There may be one of the Jocks that has posted a circle cutting jig here. They are simple to build, probably less than a hour to complete, and will save you a lot of time and grief.
Our old friend Norm has plans for several jigs at New Yankee Workshop which are very useful.
The plans are only $16.00 US
