Lansky sharpening system
Forum topic by Woodyvolt posted 12-26-2017 07:47 PM 416 views 0 times favorited 10 replies Add to Favorites Watch
View Woodyvolt's profile
Woodyvolt
12 posts in 397 days
12-26-2017 07:47 PM
The blades on my planer are needing to be sharpened. Our local sharpening service just went out of business so I was considering trying to sharpen the blades myself before having to go out of town for service.
I have a Lansky sharpening system plus an off brand “V” type sharpener. Has anyone used these methods to sharpen joiner or planer blades?
10 replies so far
View bobasaurus's profile
bobasaurus
3546 posts in 3420 days
#1 posted 12-26-2017 08:08 PM
I would use a jig with sandpaper on granite for such a wide blade that needs to be uniform across the surface.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View Rich's profile
Rich
3996 posts in 826 days
#2 posted 12-26-2017 08:58 PM
The problem with using the Lansky for that, even assuming you could get the jig to that angle, is that as the stone pivots to the side of the slot in the jig, the angle changes and becomes shallower. That’s also a factor on long knives.
You could throw something like this together pretty easily and use a stone, sandpaper, whatever:
Craftsman on the lake
2845 posts in 3674 days
#3 posted 12-26-2017 09:15 PM
I understand the desire to do it yourself. I don’t know what the blades come off from but I can get some 12 1/2” ones for my dewalt from amazon for about $35. Double sided so they’re like two sets. Jointer blades are around $16. Not worth the effort to try to get them sharpened right for me.
Woodyvolt
#4 posted 12-27-2017 12:25 AM
Thanks all for the replies. I am a novice at woodworking but hear about using sandpaper for sharping a lot, as in the above post.
My thought would be that the sandpaper would not sharpen the metal blade but I am evidently mistaken. Is there a certain type or grit that I should use?
Probably my best bet would to just take them to a professional sharpener or purchase new.
View Mario's profile
Mario
182 posts in 3632 days
#5 posted 12-27-2017 12:43 AM
Unless your blades are badly nicked, your best option is a jig like the one Rich is posting and either, sandpaper (220, 360, 400 and 600) or water stones, you will save a lot of money, buying new blades or getting them sharpened by a pro gets expensive over time and it is really a simple procedure.
Woodyvolt
#6 posted 12-27-2017 12:52 AM
Mario, is this just typical sandpaper or does it take something special?
View Rich's profile
Rich
#7 posted 12-27-2017 12:53 AM
I don’t think the factory edge is ready for use on new blades. I have a Tormek with the planer/jointer attachment and sharpen and hone even new blades.
To use a jig like the one I posted a photo of, you’ll need a flat surface and wet/dry paper. You can get a 1/2” glass plate for the surface and some 600 and maybe 1500 or 2000 grit wet or dry paper. Use a spray bottle and spritz the glass so the paper will stick to it, then spray the paper and grind away. A sharpie is useful to gauge your progress. Use the sharpie to color the flat of the blade so you can see how flat you’re getting it. Once the ink is completely gone, the faces are flat and you should have sharp blades. You can remove the burr by rubbing the backs of the blades on the finest paper you used while it’s still on the glass plate.
Finally, honing on a leather strip with compound will get it razor sharp, but don’t sweat it if you don’t want to bother. It’s easy on the Tormek, so I do it.
Woodyvolt
#8 posted 12-27-2017 01:05 AM
Rich, if I would build the jig as shown, how do I determine the proper angle? Is this guess work or can I find specs for that particular blade?
View Rich's profile
Rich
#9 posted 12-27-2017 01:10 AM
You should be able to approximate it based on the current angle on your blades. It’s not critical that it be precise down to the degree, it’s mainly important that the edge is straight and true. That’s why you need a glass plate or some other very flat surface.
Woodyvolt
#10 posted 12-27-2017 01:14 AM
I think that I have adequate information now to handle my situation. I am new to Lumber jocks and appreciate all of the reply’s and help that I received.
Thank You,
Jim
