Forum topic by MikeOB | posted 03-13-2011 02:03 AM | 978 views | 0 times favorited | 5 replies | ![]() |
On a TV stand I am making, I have the bottom doors that open outward from each other. How much of a gap should I allow between the doors so the will not rub. It is a perfect fit now closed, but by the time I add a few coats of varnish and 3 coats of poly, they will rub pretty bad. Any suggestions for how much I should shave off each door or total? Would you suggest I use a table saw or my jointer to do this. -- Mike, Portage, WI |
5 replies so far
#1 posted 03-13-2011 02:40 AM |
Mike, When I’m fitting doors or drawers on a project, I try to leave at leasat a 1/8” or little under to prevent that from happening. With the finish applied, and changes in humidity, you ned to leave room to keep them from rubbing…..I keep a thin shim on hand for just that reason….. Rick. EDIT: I’d use the jointer and shave off about a 32nd or 64th of an inch on each door…that should be enough, with waht your gonna leave for the gap. -- " At my age, happy hour is a crap and a nap"..... |
#2 posted 03-13-2011 02:53 AM |
If the stuff is easily planable, Mike, you might taper the back side of the leading edge of the doors leaving 3/16 or so square. Then for sure they won’t rub when one’s closed and the other closes to it. And if, later, you need to take a smidge off one, it’s an easy stroke or two and done. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#3 posted 03-13-2011 02:55 AM |
btw, what’s with all the coats, some of varnish and three of poly? Seems like a lot of build. Is this a cabinet for the front porch of a submarine? : ) L. -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#4 posted 03-13-2011 03:13 AM |
kind of…a 6 yr old’s room. 2 coats of poly I meant. only 1 on the non important parts -- Mike, Portage, WI |
#5 posted 03-13-2011 08:08 PM |
Lee’s suggestion about tapering the leading edges of the doors is the answer. You can keep the gap to a minimun that way. -- bill@magraphics.us |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28052 |
CNC Woodworking
211 |
Hand Tools
5407 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
