Dining table leaf extensions
Forum topic by WalkerTexasRanger posted 12-26-2017 05:59 PM 257 views 0 times favorited 2 replies Add to Favorites Watch
View WalkerTexasRanger's profile
29 posts in 1234 days
12-26-2017 05:59 PM
I am building a dining table from walnut and cherry. 7’ x 3.5’. I am going to cut the table in half and insert a pair of leaf extension slides. (Probably two 12” extensions.) A few questions:
1. Which is better: steel or wood?
2. Which is better: if steel, the type which attaches to the side apron rails or to the bottom of the tabletop?
3. Finally, if steel, all I need is 26” and Rockler is out of extensions until late January. Any other quality provider of steel extensions out there?
Thanks, WTR
2 replies so far
View pintodeluxe's profile
5596 posts in 2749 days
#1 posted 12-26-2017 07:11 PM
I used wooden slides with metal gears. I like the equilizer style slides that can be opened with just one person. Pull on one end to elongate the table, and both sides move outward.
Extension table blog…
I used slides with 50” clearance when open to accommodate two leaves lengthwise.
Buy them here…
Or perhaps here…
Good luck with it.
View Rick's profile
9224 posts in 2969 days
#2 posted 12-27-2017 11:08 PM
You might want to try Lee Valley/Veritas. IF this Link works it will take you to the Hardware Section. Table Hardware is second from the end. HERE:
Goodness me! It Worked!
Rob Lee, The Owner, Has been a member on Lumberjocks for over 3,000 days.
Hope everything works out for you Walker!
P.S. This is the link for their “Woodworking Home Page” if you want to have a Look Around.
NO! I have absolutely NO Financial or Other Interest in Lee Valley. I just use a number of their tools.
-- signature line goes here. Why here?
