Narrow pieces on track saw
Forum topic by Carloz posted 12-26-2017 04:18 PM 269 views 0 times favorited 2 replies Add to Favorites Watch
View Carloz's profile
Carloz
1147 posts in 707 days
12-26-2017 04:18 PM
Is it safe to clamp a board to the bench , lay loose another board mext to it, then put a track on top so that the track edge only covers a narrow strip of the clamped board and cut off that piece with a track saw?
The loose board is only there to support the track.
The cut off trip remains under the track.
2 replies so far
View cabmaker's profile
cabmaker
1740 posts in 2924 days
#1 posted 12-26-2017 04:36 PM
I think i understand what you asking, but the important question would be what do you think,,,,,,,your the one there,,,,,no one here can see the narrow strip you describe
Things that come to mind:
What is your bench height
how narrow is the strip
what is its purpose
what saw are you using
does it track straight
are you competent with this saw
why not use a table saw
are you uncomfortable using a tablesaw
how critical is the finish cut on said piece
will you also have a sacrificial layer on your bench or is your kerf going to be overhanging
Because you asked,,,,,,I would say no,,,,,,but if you want to experiment,,,,,thats ok too
View Ripper70's profile
Ripper70
1111 posts in 1024 days
#2 posted 12-26-2017 05:12 PM
Ask yourself, “What could possibly go wrong?”. Then, decide if there are any scenarios where something bad might happen.
From what you describe, it may be safer to have the loose board cut a bit longer than final length and screw the ends down to your bench. Then, you can simply cut of the ends of the boards where the screw holes are. This way your piece is secure.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
