Finish on Corner of bench rubbed off
Forum topic by Pompeio posted 12-26-2017 02:21 PM 333 views 0 times favorited 2 replies Add to Favorites Watch
View Pompeio's profile
Pompeio
9 posts in 425 days
12-26-2017 02:21 PM
My first project is making a sitting bench from a 7’ piece of box alder I got for $20. I sanded it for hours by hand and then used a General Finish stain and topcoat. I had to set the project aside for a while and it appears that something rubbed against a corner and removed some of the stain.
My question is whether it would be okay to just sand, restain and topcoat the affected area or should I do more?
2 replies so far
View Mike_D_S's profile
Mike_D_S
553 posts in 2449 days
#1 posted 12-26-2017 03:25 PM
I’ll start by saying that I don’t have the touch up skill set some other guys do. 75% of my touch ups turn into complete refinish on the damaged side.
For a large piece, I don’t think you have any risk to try the spot touch up. The biggest challenge I always find is getting the right blended transition between the original stain and the new stain. I have a tendency to end up with a visible transition where I can see some color variation. So I’ll usually lightly sand and then re-stain an check the color. In the 1 of 4 where the transition is not obvious, I’ll go ahead to topcoat.
But it seems that most commonly I’ll have to go ahead and take the whole surface down to bare wood and start over. Of course it also matters where the spot is. On the sides and less visible spots, I’m less picky.
But I’ve seen guys do perfect repairs, so hopefully you’ll get better input from someone who has a higher success rate than me.
Mike
-- No honey, that's not new, I've had that forever......
View bilyo's profile
bilyo
468 posts in 1337 days
#2 posted 12-26-2017 10:06 PM
- Pompeio
A photo would be very helpful. If, in fact, the abrasion removed both the top coats and stain down to bare wood then you have a bigger problem than if only the top coat is damaged. As Mike said. making that kind of “blend” takes skill, and patience. Without better advice, I would say you are looking at a redo. This may depend on how perfect you need the repair to be.
