| Forum topic by trainwreck | posted 803 days ago | 5018 views | 0 times favorited | 73 replies | ![]() |
803 days ago |
OK….kiln dried 2×4 studs, 2 1/2” wood screws. I am drilling a pilot hole, but as soon as I get through the 1×4 to the 2x, the screw strips out. What gives? I’m building some lawn chairs for around my fire pit. These 2×4’s are making me crazy! Thank God for vise grips, but man! I just wanna screw! LOL Suggestions? |
73 replies so far
#1 posted 803 days ago |
You have to really put your shoulder and weight behind the Square drive screws are another alternative. They are a little |
#2 posted 803 days ago |
When you say “2 1/2” wood screws” do you mean drywall type screws or zinc plated screws with the hefty shank? If you are stripping out the slot because of increased friction on the shank of the screw, there would be three solutions: 1. Smaller shank 2. Predrill with a tapered bit 3. Lubricate the screw If I have one degree of uncertainty about a screw installation, I wax the screw. I use toilet bowl ring wax, but Grizzly and others sell stuff in a large caliber Chap Stick container (I have actually used Chap Stick on an install where I had forgotten my Ikempucky—another brand name of wax for screws). Oh, and a fourth: Your bit may be worn out. As it wears, it gets sloppy and angled, and wants to ride out of the slot. Even if good quality bits cost twice what a drug store brand costs, you’re what, out a coupla bucks? Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#3 posted 803 days ago |
I have been putting my weight behind the drill and making sure it’s straight and inline with the screw. Looks like a trip to the hardware store for me for some square drive screws and a driver bit, huh? |
#4 posted 803 days ago |
I would question the type of tip you are using first. Is it the best match for the screw? I modify my bits by grinding off the very tip of a Phillips bit. My theory being that the very tip provides no traction to the application of torque. The wings of the bit must be fully engaged. Hope this helps. -- Mel |
#5 posted 803 days ago |
BIG fan of Lee Barker’s #3. I bought a toilet wax ring, and stuffed it into a plastic “can.” Before driving long screws, I shove the screw into the can, coating the threads with the wax. DRAMATIC reduction in torque required to drive the screws > longer battery life, on cordless drivers > never strip them out, any more :-) -- -- Neil |
#6 posted 803 days ago |
My bit fits perfectly into the screw, and it is a new bit, but it’s cheap, I think—it was a gift from my father. The screws are 8×2 1/2 and coarsely threaded. They says they’re steel, but I’m pretty sure they’re plated with something. Actually, as I look at them more closely, it looks like I can use a No. 2 square bit with them, so maybe I’ll just try that and report back! |
#7 posted 803 days ago |
maybe you need those ‘deck screws’ -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#8 posted 803 days ago |
OMG! I had a 2 square bit. That thing is my new best friend! These babies go through like butter! Thanks guys! |
#9 posted 803 days ago |
I have a small fridge in the shop, so I keep the bowl ring in the fridge when not in use. They can get kinda messy during Mississippi summers if not kept cool. Bowl ring seal=cheapest screw lube goin’. -- bill@magraphics.us |
#10 posted 803 days ago |
I was down in the states a while ago and see they have a screw that is a cross between a Phillips and a Robertson should be a real dandy. -- I started off with nothing I have most of it left |
#11 posted 803 days ago |
So I’m making 4 lawn chairs which means 40 slats for the seat/backs. Drilling pilot holes in an assembly line fashion….no problem except I melted my bit because I was going so fast. LOL |
#12 posted 803 days ago |
Stormin, there’s a general rule I find that applies impressively often in my world: If it’s made to do two or more things, it probably won’t do any of them real well. I find that true of the combination head screws. Allowing the space in the center for a Robertson bit subtracts surface for the Phillips head and vice versa. I have a large box of these, 1 1/2” long, silver zinc, and they’re yours, just come pick them up! Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#13 posted 803 days ago |
Re: the toilet ring David’s suggestion for screws is right on! If the chairs are for outdoor use especially. Another good screw is ””Timber Locks””:http://www.castlewholesalers.com/TIMBERLOCK-6-Screws-Box-of-50.html But, I think 6” is the shortest. I’ve used them up to 10”. They have heads that require a socket type driver, like metal roofing screws. Threads up about 1/3 and then, a smooth shank. Great for timbers. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#14 posted 803 days ago |
I agree with Lee, when you go to Home improvement store, buy a toilet wax seal and lubricate the screws, a good cheap solution. -- TheOldTimer,Chandler Arizona |
#15 posted 802 days ago |
Go buy some SPAX screws at the big box store. Drill the pilot into the 1×4 if you wish with a nice countersink. Then drive them in. SPAX do not need to be pre-drilled. You can drive a SPAX into end grain Maple without drilling a hole first. You can choose one with square, phillips or SPAX heads. -- Les, Arkansas, www.woodthatrocks.com |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15791 |
Hand Tools
2037 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
