Breadboard tenon length on large breadboards
« back to Joinery forum
Forum topic by AJacob posted 12-26-2017 02:20 PM 516 views 0 times favorited 2 replies Add to Favorites Watch
View AJacob's profile
AJacob
1 post in 302 days
12-26-2017 02:20 PM
I’m building a table with breadboards that 38” long X 1 1/2 thick X 10” wide. The wood is douglas fir. How long should I make my tenons. I’ve read the length of tenon is at least 5x the thickness of the tenon. Tenon is 1/3 the thickness of the wood, so the tenon will be 1/2 inch, making the tenon 2 1/2 inches long at least. That seems to short for 10” wide breadboar. How long would you all recommend?
2 replies so far
View JBrow's profile
JBrow
1366 posts in 1069 days
#1 posted 12-31-2017 03:00 AM
AJacob,
I am a long way from being an expert on breadboards so I am not sure why the rule of thumb you cited exists. Absent this understanding, I agree that a 2-1/2” long tenon seems short for a 10” wide breadboard. But if the breadboard remains flat over time, 2-1/2” long tenons may be sufficient. My only concern is that tenons too short might cause the breadboard connection to fail should someone sit on the breadboard. I cannot say whether this is a real or imaginary concern.
The only problems I can foresee with longer tenons is chopping well-fitting deep mortises would be more difficult. Also a 10” wide board with long tenons that are pinned too far away from the table top/breadboard joint could cause the breadboard to crack. If pinned close to the table top/breadboard joint, then the breadboard could still expand and contract.
I assume there is a good reason for such a wide breadboard. If reducing its width is not practical, then ensuring the breadboard is quartersawn could at least reduce or eliminate cupping of the wide breadboard. I doubt that longer tenons could resist the forces associated with a cupping breadboard.
View pintodeluxe's profile
pintodeluxe
5758 posts in 2962 days
#2 posted 12-31-2017 05:29 AM
10” breadboards are too wide. Other than aesthetics, there is no reason for a breadboard wider than 3-1/2” – 4”.
In the case of these standard dimension breadboards, the tenons can be about 2-1/2” long.
