Finishing Kitchen Cabinets
Forum topic by Panthers65 posted 12-25-2017 06:57 PM 821 views 0 times favorited 14 replies Add to Favorites Watch
View Panthers65's profile
Panthers65
12 posts in 432 days
12-25-2017 06:57 PM
Thanks for the help in advance. I’m finishing up some kitchen cabinets and my wife wants SW Antique White on them. I have a large air compressor and a HF purple HVLP spray gun, but I’m not sure if spraying is the best way to finish these cabinets. The cabinets are raw now, what would be the best way to finish these?
I’m thinking:
Orbital sand with 150
Shoot primer (suggestions?)
Orbital sand with 220
2 coats of antique whitepre cat
some type of sealer?
If there is a better way to do these, I’m all ears. Thanks!
14 replies so far
View LesB's profile
LesB
1801 posts in 3563 days
#1 posted 12-25-2017 07:23 PM
What kind of wood is it?
I’m thinking a second coat of primer sanded again with 320 or 400.
With a catalized top coat you probably don’t need a sealer but check with the manufacturer on that.
-- Les B, Oregon
Panthers65
#2 posted 12-25-2017 08:04 PM
Poplar for the face frames, sandeply plywood boxes.
View jbay's profile
jbay
2603 posts in 1019 days
#3 posted 12-25-2017 08:21 PM
Thanks for the help in advance. I m finishing up some kitchen cabinets and my wife wants SW Antique White on them. I have a large air compressor and a HF purple HVLP spray gun, but I m not sure if spraying is the best way to finish these cabinets. The cabinets are raw now, what would be the best way to finish these?
I m thinking:
If there is a better way to do these, I m all ears. Thanks!
- Panthers65
I would sand to 220
spray 1 coat of SW primer undercoat (this primmer powders up and sands baby butt smooth, very nice primmer)
lightly sand with 320
Spray second coat of same primmer
Sand with 320
Spray antique white (pre-cat)
Spray final coat
Shouldn’t be a need for any top coat after that.
Another option would be to have the primmer tinted to the antique white
Spray a couple of coats (sanding in between coats as above)
Then top coat with 2 coats of clear pre-cat ( sheen of your choice) I prefer the SW dull rubbed.
View ArtMann's profile
ArtMann
1046 posts in 936 days
#4 posted 12-26-2017 12:15 AM
I am not sure why you would want to apply a sealer. I doubt if it would be any more durable than just the tinted lacquer.
View ChefHDAN's profile
ChefHDAN
1123 posts in 2970 days
#5 posted 12-26-2017 03:01 AM
Have you shot any latex or primer through your gun? I’m soon to start the same task, have been trying to find a larger nozzle for the thicker paint to spray, curious to hear how your gun handles the paint?
5072 posts in 2613 days
#6 posted 12-26-2017 11:59 AM
I agree with Art, why did you want to put on a sealer? The lacquer will be plenty durable. Also, using an ROS to finish sand is asking for pigtails in your finish, unless you follow it with a hand sanding.
Panthers65
#7 posted 12-26-2017 01:51 PM
I would sand to 220
Sand with 320
Spray final coat
Shouldn t be a need for any top coat after that.
- jbay
Thanks, would there be any different in the two as far as durability/ease of application? Seems like either way I’d be buying primer and pre-can and applying the same number of coats.
- ArtMann
- Fred Hargis
Just what I’m use to, apply the color then seal it. If it’s not necessary I’m all for removing a step. So I should just ROS Sand the bare wood, and then block/sponge sand between coats?
Have you shot any latex or primer through your gun? I m soon to start the same task, have been trying to find a larger nozzle for the thicker paint to spray, curious to hear how your gun handles the paint?
- ChefHDAN
I haven’t shot latex through it, from what I’ve seen the 1.4 tip on the HF gun is much too small. I did spray a dresser in pigmented lacquer from SW and it sprayed nice. HF has a couple of the suction fed cup guns that come with a 1.8 Tip, but I’m still not sure if that would be big enough. They are cheap enough and Ive got a good drill press down stairs, I might try and buy a gun and drill one out to a 2.2 and see if it would spray latex then.
View jar944's profile
jar944
127 posts in 1558 days
#8 posted 12-26-2017 03:09 PM
I’m a fan of solvent lacquer if your area allows it.
This is a set of pantry cabinets I recently finished. Poplar face frames ro sanded to 180
1 coat of high build undercoater
Hand scuff sanded with 320
2 coats of Precat lacquer
View CharlesNeil's profile
CharlesNeil
2434 posts in 3991 days
#9 posted 12-26-2017 03:23 PM
1.8 is sufficient for latex, however it doesnt make for a very durable finish on cabinets , unless you clear coat it .
You cant simply drill out a nozzle , the needle wouldnt match and it would leak ,
Panthers65
#10 posted 12-26-2017 03:26 PM
- CharlesNeil
Thanks.
Does anyone know the viscosity of the Kem Aqua Surfacer? Reading more into the Kem Aqua Plus it seems to be a very thin material that would spray well through my current 1.4 Tip, but I haven’t found any idea on how thick the Kem Aqua Surfacer is and if I would need the 1.8 tip or not.
View rwe2156's profile
rwe2156
3073 posts in 1601 days
#11 posted 12-26-2017 03:36 PM
IMO spraying is the ONLY way to finish cabinets. You can spray latex through a 1.4 tip, but its tricky and requires a lot of thinning. Several YT videos on this. I chose to use oil base paint (if your state will allow it).
I had my first try at HVLP spraying on a bathroom vanity build. I used SW Pro Block primer and SW ProClassic for the top coats. The HF purple gun worked fine once I learned how much to thin the paint. (BTW they are on sale today for $9.99). I did 2 coats of primer & hand sanded 220 between coats, then 2 coats of the PC.
I would not use an orbital sander between coats you will risk sanding the paint off especially on corners.
I ran the stiles, rails and panels through a drum sander & painted the panels prior to installation (caution: doing this will result in the panel being too tight so make the grooves a bit sloppy of course this depends somewhat on what type profile you use).
The biggest thing I learned is do not rush through the prep. With paint even the most miniscule defect will show up.
CharlesNeil
#12 posted 12-26-2017 03:44 PM
Kem Aqua sprays well , just use the paint as the primer , unless its MDF ,
shoot a wet coat, let dry , good scuff sand with some 220 or finer for first coat, there after 320 .
I spray it with a 1.4 straight from the can .
View Joel_B's profile
Joel_B
347 posts in 1501 days
#13 posted 01-03-2018 04:06 PM
I have plans to spray my kitchen cabinets and decided I would use Emtech EM6500 instead of Latex. It is supposed to spray better than Latex. You can order it in any SW color.
-- Joel, Encinitas, CA
View DS's profile
DS
2978 posts in 2541 days
#14 posted 01-03-2018 04:56 PM
I agree with jbay. Two coats of primer, your color coat, optional 2nd color coat and done
Sometimes, if I add an antiquing glaze over the color coat, I will add a clear top coat, but otherwise, it is not needed.
