Attaching Table to Porter Cable Drill Press
Forum topic by hightide posted 805 days ago 4982 views 1 time favorited 9 replies Add to Favorites Watch
View hightide's profile
hightide
10 posts in 863 days
805 days ago
Topic tags/keywords: drill press table
Hey guys.
I just got a Porter Cable drill press (15” Floor) from Lowes. I know that I will need a table with a fence and I have all that I need to make one. What I noticed though is that the stock table that comes on the press does not have holes through it to attach an aux table. It does have t-channels though. I have attached a coupld of pics. Most how-to’s that I have seen on drill press tables show the base as having holes all the way through so you can attach bolts to the bottom of the table. Any thoughts on how to attach a table to this model? Thanks!
Hank
-- .: HH :. Daniel Island SC - www.plankinmyowneye.com
9 replies so far
Rick Dennington
2889 posts in 1367 days
#1 posted 805 days ago
Hank,
Since your table does not have holes to mount a table on, you’ll have to drill some. Drill 4 holes in the slots….one in each slot…Probably 1/4”—3/8” should be big enough. Loosen the handle underneath the table, and rotate the table to get the holes across from one another. Then you can make an auxilary table, drill holes in the bottom, and mount the table to the drill table through the holes with bolts, wahers, and nuts..good to go.
-- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!!
View lew's profile
lew
8989 posts in 1928 days
#2 posted 805 days ago
I think I would counter sink bolts into the auxiliary table then use nuts and fender washers in the slots. Because the slots are positioned as they are, you would probably have to place the bolts near the open ends in order to utilize all four of the slots.
Just my thought.
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
Rick Dennington
#3 posted 805 days ago
Lew,
You’re right….. I didn’t see the slots were open on the ends so you could slide a washer and nut in them, drill up through the bottom of the auxulary table and mount the bolts that way. Sorry, Hank…I just didn’t look close enough at the drill table…
hightide
#4 posted 805 days ago
Thanks for the advice guys!
View DIYaholic's profile (online now)
DIYaholic
7337 posts in 847 days
#5 posted 805 days ago
Duct Tape? Lol.
-- Randy-- I may not be good...but I am slow!
View syenefarmer's profile (online now)
syenefarmer
332 posts in 1253 days
#6 posted 805 days ago
How about doing something like this, securing a drill press table.
hightide
#7 posted 804 days ago
Thanks syenefarmer. After a little more research I found that the Rockler drill press table attaches like the link you posted. That does seem to be the best way. I will post pics once I get to it to show you guys how I go about it…Thanks!
View Danuuc's profile
Danuuc
1 post in 197 days
#8 posted 197 days ago
Working on my drill table for my new Porter Cable drill as well. Looks like the same table.
I’m thinking of mounting a dowel in the middle that aligns with the center hole.
Maybe some additional guides on the bottom of the extended table.
If that doesn’t work, I’ll drill and tap some new holes.
View NiteWalker's profile
NiteWalker
1483 posts in 749 days
#9 posted 196 days ago
IMHO, I would just drill through the cast iron.
If you don’t want to do that, I’d either get some bigger washers and grind flats on opposing sides, or get square nuts (mcmaster has them IIRC), and use screws from the top.
Here’s how I did mine:
I have the ridgid press, which has holes all the way through, but if they didn’t, I’d just do what I mentioned above.
