What size compressor for pin nailer?
Forum topic by patcollins posted 03-12-2011 12:05 AM 1590 views 0 times favorited 5 replies Add to Favorites Watch
View patcollins's profile
patcollins
1687 posts in 2981 days
03-12-2011 12:05 AM
I have a small portable 1 Gallon tank Cambell Hausfield aircompressor that I use for airbrushing and wondered if it was enough to use with a pin nailer. I can’t see myself putting more than 20 pins in at a time and was wondering if my compressor would be enough to do this without constantly running.
5 replies so far
View cabmaker's profile
cabmaker
1740 posts in 2924 days
#1 posted 03-12-2011 12:11 AM
I have a large, medium and a very small compressor. I think it is a one gallon. I can pick it up with two fingers easily, thats why I got it. It will shoot 12-13 5/8 inch 23 ga. before cycling. It will shoot 6-8 2inch 16 ga. between cycles. Hope this helps you. I also have a tiny wire nailer that will go maybe 30 shots before cycling the compressor.
View Loren's profile
10477 posts in 3763 days
#2 posted 03-12-2011 12:20 AM
Yes. It’s enough.
View allmyfingers's profile
allmyfingers
40 posts in 2762 days
#3 posted 03-12-2011 01:37 AM
we use a pancake compressor for on the job work. our fasco pin nailer drives 2” pins into mahogany at 90psi
-- I cut it 3 times and it was still too short?!?
View tenontim's profile
tenontim
2131 posts in 3860 days
#4 posted 03-12-2011 02:03 AM
Pat, I think you can put the hose in your mouth and blow enough pressure into it to run a pin nailer :)
patcollins
#5 posted 03-12-2011 03:43 AM
I was thinking how much could it take, just wanted to verify before I got one and couldn’t do anything with it.
