Kitchen drawer boxes (plywood) what joint to use?
« back to Joinery forum
Forum topic by icandothat posted 12-22-2017 09:54 PM 838 views 0 times favorited 27 replies Add to Favorites Watch
View icandothat's profile
icandothat
16 posts in 361 days
12-22-2017 09:54 PM
I’m replacing some 30 year old drawer boxes. About 15 or them.
Have 1/2” plywood (maple venner).
Tried doing half blind dovetails, even used sacraficial backer when cutting, but the pins kept falling apart. Guess the plywood has air pockets or some other issue.
Should I just miter then glue and put 2 18g brads in each corner?
Or should I rabbet or …?
1/3 of the boxes will have drawer fronts. Rest will be pull out pantry boxes.
Thanks for the input!
27 replies so far
View Loren's profile
9964 posts in 3555 days
#1 posted 12-22-2017 10:03 PM
I use rabbets and brad nails for drawers using
ball bearing slides. I use a brad about every
inch and a half. I don’t think the rabbets are
much stronger than butt joints but the rabbet
helps in assembly. I’ve used drawer lock joints
too.
One reason I like rabbets is that when the ply
is edgebanded prior to rabbeting there’s a very
low reject rate when routing the rabbets. With
tongued profiles I’ve had some issues with the
edgeband getting torn up. I use a backing block
but I still had some rejects.
Dovetails are a great choice for wood-on-wood
slide action, but for modern steel slides
the strength of dovetails is generally overkill.
View jbay's profile
jbay
2050 posts in 806 days
#2 posted 12-22-2017 10:18 PM
This is what I do.
I prefer to use 5/8” though.
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
View cracknpop's profile
cracknpop
282 posts in 2256 days
#3 posted 12-22-2017 10:24 PM
I’ve used a dado/rabbit type joint on numerous plywood drawer boxes with good results. I used a router table in the past but find the table saw to be much faster.
Here’s a pic of file drawer and even with heavy use, it has held up very well.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
cracknpop
#4 posted 12-22-2017 10:25 PM
Great minds think alike, I see jbay posted while I wasn’t watching…
View DalyArcher's profile
DalyArcher
114 posts in 1026 days
#5 posted 12-22-2017 10:30 PM
dados on the back, locking rabbets on the front. good quality glue and a few brads or staples if you feel the need.
View BobAnderton's profile
BobAnderton
247 posts in 2697 days
#6 posted 12-22-2017 10:44 PM
Consider this
Lock miter bit. #22627 is for 3/8” to 3/4” thickness
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
View cabmaker's profile
cabmaker
1696 posts in 2716 days
#7 posted 12-22-2017 11:08 PM
What kind of joinery did you find on the thirty year old drawers you are replacing ?
View Carloz's profile
Carloz
1147 posts in 498 days
#8 posted 12-23-2017 12:36 AM
Consider this
- BobAnderton
On plywood ?
icandothat
#9 posted 12-23-2017 01:41 AM
Thanks for all the input guys!
When doing a rabbet, do you guys band the front so the plywood doesnt show on pantry drawers?
As for the old cabinets, it was falling apart, believe it was all butt joints, chucked it out a while back.
View GR8HUNTER's profile
GR8HUNTER
3293 posts in 619 days
#10 posted 12-23-2017 01:49 AM
jbay has the plan :<))
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
runswithscissors
2655 posts in 1932 days
#11 posted 12-23-2017 02:15 AM
I have generally had poor success cutting dovetails in plywood (with a jig). So when I made my kitchen drawers, I used all solid wood, 1/2” I believe. That’s why we all have planers now, isn’t it?
The last joint I would use on any drawer would be a miter joint.
I realize dovetails are overkill, but an advantage is that, once properly cut, they practically assemble themselves. And if you’re doing a lot of them, you can really crank them out once the jig is set up and the router dialed in.
#12 posted 12-23-2017 02:22 AM
I don’t.
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2216 days
#13 posted 12-23-2017 02:32 AM
What jaybay and cracknpop said. I like that joint.
Once in a while I’ll do box joint on BB plywood, no tear out on the table saw.
icandothat
#14 posted 12-23-2017 02:24 PM
Thanks!
I’ll do a 1/4 rabbet.
Do you guys prefer doing that on the table saw or the router?
GR8HUNTER
#15 posted 12-23-2017 02:36 PM
for me its the TS most of the time :<))
