Neat Home Made Accessory For The Lathe
Forum topic by lew posted 03-11-2011 05:33 PM 2908 views 1 time favorited 2 replies Add to Favorites Watch
View lew's profile
lew
11896 posts in 3630 days
03-11-2011 05:33 PM
Topic tags/keywords: jig turning
Just received this link for a nice accessory for the lathe. Thought I’d pass it on.
http://www.davidreedsmith.com/Articles/DrillGuide/DrillGuide.htm
Lew
2 replies so far
View poopiekat's profile
poopiekat
4322 posts in 3609 days
#1 posted 03-11-2011 06:02 PM
I’ve got one of those old B&D drill guides that I thought about adapting to my lathe, with a piece of angle stock bolted to the bed. This design makes a whole lot more sense! Thanks for posting!
View Don Johnson's profile
Don Johnson
680 posts in 2655 days
#2 posted 03-11-2011 08:12 PM
I used to make wooden pots/bowls for my wife Avril to go with the enamelled copper lids that she produced. At craft fairs, people would lift the lids to look inside, and I eventually realised that they were expecting to find pot-pourii within.
We decided that including pot-pourri would be a good idea, but as she didn’t want holes in the lid, I had to make holes in the bowl.
I did this by means of a steel bar that fitted my lathe tool rest holder, which had a 1/4 ” diameter drill bush pressed into it near the top. This bush acted as a guide for a bit in a small power drill. I indexed the bowl around its diameter to make about 12 holes to let the perfume escape, and this worked well.
I only used one size of drill, but if the bush were an easy fit in the bar, and locked by a screw, the system could use interchangeable bushes for different drill sizes. See crude drawing (the very top element represents a screw inserted into a tapped hole in the bar end):
As an amazing coincidence, as I was posting this comment, I Googled ‘pot-pourri bowl’ to find the correct term for Avril’s items, and what did I find but an advertisement for someone selling one of hers on EBay !!! It was one of the smaller versions we made, and can be seen here: http://cgi.ebay.co.uk/WOODEN-POT-POURRI-BOWL-STUNNING-PAINTED-GLASS-LID-/310302125005?pt=UK_Home_Garden_Decorative_Accents_LE&hash=item483f72abcd#ht_2845wt_1140
Just to confirm, the lid IS enamelled, i.e. a mixture of glass powder and lumps melted at red-hot temperatures onto a copper base, with the colours ‘swirled’ together with a long tool whilst the item is inside the kiln. When you realise that the swirling operation took place whilst the item was red-hot – so no individual colours could be seen – you can appreciate how clever Avril was in creating her designs.
The confusion over the word ‘enamel’ (perhaps only in the UK) was created when manufacturers started selling very high-gloss paint which they called ‘enamel’.
-- Don, Somerset UK, http://www.donjohnson24.co.uk
