Unisaw bearing replacement
Forum topic by Nubsnstubs posted 12-22-2017 06:48 PM 438 views 0 times favorited 2 replies Add to Favorites Watch
View Nubsnstubs's profile
Nubsnstubs
1434 posts in 1967 days
12-22-2017 06:48 PM
Does anyone know the thread size and pitch of the arbor bearing nut on a Rockwell 34-761 Unisaw? ......... Jerry (in Tucson)
2 replies so far
View MrUnix's profile
MrUnix
7106 posts in 2436 days
#1 posted 12-22-2017 09:11 PM
Not sure the exact measurement, but they are about $10 or less at the aftermarket suppliers. I also don’t believe there are different ones depending on tilt, as that nut is held in place via a flat disc retainer that gets a tab bent up to hold it – so one from any Unisaw model should work fine. Do you need one or just curious?
Edit: I just realized that we may be talking different parts.. there is a hex nut that threads on the end of the arbor shaft (described above^^^), and there is what is known as the large arbor bearing retainer nut that screws into the arbor housing… the later having the threads on the outside and manipulated via a pin wrench or similar. That one has an OD of 1.5” and 20 TPI. Also available at aftermarket suppliers for about $10.
MrUnix
#2 posted 12-22-2017 10:22 PM
Here be a diagram to clarify:
