| Forum topic by Dave | posted 803 days ago | 1496 views | 1 time favorited | 35 replies | ![]() |
803 days ago |
Topic tags/keywords: question pro’s anyone for either way?
-- Superdav "No matter where you go - there you are." http://chiselandforge.com |
35 replies so far
#1 posted 803 days ago |
Hey, I’m on your side. :) I hadn’t thought about #3. I’ll add that to my list. Thanks. I’m thinking the end grain affects the knife less. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#2 posted 803 days ago |
I was taught to always mark tails, cut them then mark pins from tails, I have not cut that many dovetails over the years but this way round has always worked for me but that’s it really isn’t it? If it works for you do it whichever way… |
#3 posted 803 days ago |
thanks guys -- Superdav "No matter where you go - there you are." http://chiselandforge.com |
#4 posted 803 days ago |
Glad to be of service Dave. :) I’m in charge of humor around here. Self appointed. Take care. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#5 posted 802 days ago |
Oh, oh, here comes dissent Dave. I used to be a tails first man, but now I’m a pin head. I don’t believe there is a ‘right’ way. It all comes down to personal preference and each person has their own reasons for their favorite way. Here are the reasons why pins first is better for me. 1. I like to leave the marking lines to guide my cutting. When marking with the pins that line will remain on the tails. For me this helps me make more accurate saw cuts (I need all the help I can get). 2. I leave very little space between the tails at the board end, from 1/8” to 1/16”, and I find it much easier to get my knife or pencil in through the pins than I do on the tails while marking out. I agree that pins first is a lot slower when doing multiples, but I always get a great result with pins first. When I do multiples I usually use my scrollsaw, (which tilts to both sides when I cut the pins). I think the important thing here is that we are both happy with the way we do it, and maybe for different reasons, but we both get good results. Diversity is good and gives us something to argue about, lol. -- Mike, American in Norway |
#6 posted 802 days ago |
I’m a tail guy all the way. The reason: I’ve never cut pins first! Therefore, I have no right to comment other than to say: Tails first! and steal your justification :) -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#7 posted 802 days ago |
The main reason that I like to do the tails first is that for me it is soooo much easier to position the two pieces for the marking process. For me it is harder and more awkward to hold the pin board vertically to mark the mating board that to hold the tail board horizontally. I simply put the pin board in the vise vertically with the end level with the bench top. I lay the tail board on the surface of the bench and line up everything with my fingers and mark with a marking knife or scribe. It’s so easy to do it this way and keep something from slipping. -- If a man does not keep pace with his companions, perhaps it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away. Henry David Thoreau |
#8 posted 802 days ago |
Wreck, this is precisely the reason I’ve always done it this way. One piece in the vise & the other propped on a plane. I’ve got fancy marking knives but I find a sharp tipped exacto knife to work best for me. The pin board always seemed unstable, teetering over the tail board. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#9 posted 802 days ago |
Mike, Al and Wreck I’m learning. I always use a pencil first for layout. I cant see. Then I use a knife and still draw a line over the cut and split the line when I cut.
#5. With pins first you have to stand the board up to layout the tails. -- Superdav "No matter where you go - there you are." http://chiselandforge.com |
#10 posted 802 days ago |
SD, I’ve tried using a pencil, even a fine mechanical one, but I always mis-saw. I can’t see either & I have to have a deep line, a thin-kerf saw, and a bright light! I’ve never tried splitting the mark before. By your doves above, whatever you’re doing is working. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#11 posted 802 days ago |
Bertha, my knife is not real fancy. I have one that I made from template steel that I heat treated myself but it’s just plain jane. The other is just a small simple carving knife. This is a good topic. Thanks for posting. -- If a man does not keep pace with his companions, perhaps it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away. Henry David Thoreau |
#12 posted 802 days ago |
When tails are cut first the pins can be marked by registering a chisel I find it easier to rip straight down. The slight angle of the tails is The bowsaw is “self-jigging” for cutting dovetails because you can In cutting the pins the bowsaw frame is held at an angle. This is |
#13 posted 802 days ago |
You know, Loren, I’ve never had the guts to mark my pins using a chisel but I’ve thought about it on a few occasions. I’ve also never used a bowsaw to cut dovetails. ‘don’t even own one, as sad as that is. Oh well, add it to the list of projects! -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#14 posted 802 days ago |
Al I use a 0.5 and layout the tails. I cut with a dozuki. I will still wander a bit. My dozuki once it starts on a line it stays there. I always pair or use a large rasp to square the saw marks. Lets say your cutting a 1 in 6. Even if I was off a bit, as long as it is square the eye can’t tell. Mark your pins. And Loren I do like the thought of using a chisel. I have been using a knife and there is human error (Dave). I will drag my pencil lightly over the knife mark. It will leave a light line in the kerf of the knife mark. And then I cut on the waste side. It works out for me. -- Superdav "No matter where you go - there you are." http://chiselandforge.com |
#15 posted 802 days ago |
Dave, that’s really clever using backer boards at your strike line. That’s a helpful idea & serves several purposes. I’ve always wanted a bowsaw. There’s something just “right” about a bowsaw cutting a dovetail. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1532 |
3548 |
15776 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2840 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
