1/4 vs 1/2
Forum topic by silverdog posted 800 days ago 827 views 0 times favorited 20 replies Add to Favorites Watch
View silverdog's profile
silverdog
20 posts in 829 days
800 days ago
iam going to order a 15pc router bet set from mcls on sale for 39.95. from what i have read and advise its a good starter set. what is the advanage of 1/2 in vs 1/4 in bits. they are both the same price.
20 replies so far
View cabmaker's profile
cabmaker
1023 posts in 975 days
#1 posted 800 days ago
smoother operation. More beef
View Gene Howe's profile
Gene Howe
3184 posts in 1595 days
#2 posted 800 days ago
Depends on the bit. “Most” straight bits are OK with 1/4” shanks. I prefer 1/2” shanks on winged bits, even round overs. Also, 1/2” shanks are heaver and dampen the shock to the bit as it hits the wood. I’ve bent and/or broken a few 1/4” shanks, so I’m leery of them.
Consequently, nearly all of mine are 1/2”. I hate changing collets and those 1/4” inserts are also a pain and, if you don’t get the good ones, the bit often slips.
View bigike's profile
bigike
4023 posts in 1455 days
#3 posted 800 days ago
1/4” bits sometimes can chatter across the wood and leave a rough finish it’s always better to get the 1/2” bits if at all possible. This was my experience with a 1/4 flush cutting bit just before the shank bent still in the router collet.
View reggiek's profile
reggiek
2238 posts in 1436 days
#4 posted 800 days ago
Less chance that a bit will bend or break on the 1/2 inch…..more beef as Cabmaker says….they stay better in the collet….easier to tighten…...I always buy 1/2 inch if they are available. I get the 1/4 when I can’t get the 1/2.
There are only a few drawbacks to the 1/2 inch…..one is they take more space in your drawer or bit case….the other is that some mfg’s charge a few bucks more for them.
View Pete_Jud's profile
Pete_Jud
407 posts in 1919 days
#5 posted 800 days ago
I only order 1/2 inch bits. They are stronger, and less chatter.
-- Life is to short to own an ugly boat.
silverdog
#6 posted 800 days ago
sounds like the decision is clear, 1/2 in. thanks everyone. LJ is once again is saving me money.
View Resurrected's profile
Resurrected
671 posts in 858 days
#7 posted 800 days ago
Chatter is the main reason usually cost is not any different or negligible.
-- Who can I block now???????????????????????
View therookie's profile
therookie
891 posts in 993 days
#8 posted 800 days ago
I can agree with the 1/2” but if you only have a 1/4” router, then it is pointless
-- http://aewoodworks.webs.com
View richgreer's profile
richgreer
4474 posts in 1241 days
#9 posted 800 days ago
Real simple question and answer. Push a 1/4” shaft a little too hard and you get a broken shaft. That is never a problem with a 1/2” shaft. I’ve learned this the hard way.
View surfin2's profile
surfin2
40846 posts in 1302 days
#10 posted 800 days ago
Depends on the bit. “Most” straight bits are OK with 1/4” shanks. I prefer 1/2” shanks on winged bits 1/2” shanks are heaver and dampen the shock to the bit as it hits the wood.
Go for the 1/2 _
-- Rick
silverdog
#11 posted 800 days ago
ok now you got me scared, I just asumed all routers took 1/4 and 1/2 in bits. the model numbers I have are craftsmans 315175304 and 315175130. do they take both? sorry about this guys, I am new at this. I have already ordered the 1/2 in.
4873 posts in 1814 days
#12 posted 800 days ago
When I was starting out I bought a big 1/2” router and
always bought the 1/2” cutters. I figured beafier was
better… then I discovered the laminate trimmer and later
the Festool OF 1000 -
.... and of course 1/2” bits don’t fit these little go-anywhere
routers.
If I were buying bits in sets I’d get 1/4” ones but only small
cutters. I’m a detail-oriented guy and I like light, maneuverable
routers for smaller details.
The 1/2” bits I’ve always bought one at a time on an as-needed
basis. I reckon I’d never use about half the 1/2” bits in a given
set. The 1/4” ones are more versatile for me.
reggiek
#13 posted 800 days ago
The majority of routers on the market will have a 1/2 and 1/4 collet set (in the USA). Trim Routers, two models of Festool and most European routers do not accept 1/2 (some have add on accessories for them though). If you have a standard router….then the 1/2 are fine…...if you don’t…then you will need to get the 1/4 or the metrics. I have a trim router and several 1/4 that I only use in it…...with the higher amp (or higher Hp) routers…..always get the bigger bits when available.
View BreakingBoardom's profile
BreakingBoardom
613 posts in 1247 days
#14 posted 800 days ago
Do you have the owners manual for your router? It should say whether it takes both 1/2” & 1/4” or not. From trying to find that router online, I came across parts for the 315175340 (not the 315175304) and it only shows a part for 1/4” collet. Not sure if it’ll take 1/2” bits. Can anyone confirm? Anyone else that router?
-- Matt - http://breakingboardom.wordpress.com/
View dbhost's profile
dbhost
4748 posts in 1398 days
#15 posted 799 days ago
Always buy 1/2” shank bits unless the profile you need isn’t available in 1/2”. They are more stable, and MUCH stronger. I have broken more than a few 1/4” shank bits out of slight lapses in judgement that would not have even phased a 1/2” bit…
