How Do I Protect Logs From Bugs?
Forum topic by PG_Zac posted 12-22-2017 12:30 PM 539 views 0 times favorited 12 replies Add to Favorites Watch
View PG_Zac's profile
PG_Zac
368 posts in 3468 days
12-22-2017 12:30 PM
Topic tags/keywords: question preserving silver oak
So, in April 2016 I had to fell a large Silver Oak in our back yard as it was threatening to fall & damage buildings. Obviously I decided to keep the wood for future projects even though I had no idea what the wood was like.
This morning I took one of the small branches to the bandsaw to slab it just to see what it is like on the inside.
(just beautiful by the way) I know it isn’t dry enough to be used, but I thought it’s time to see what we have, and maybe slab some so that it can dry quicker.
I found that termites and other borers have been snacking on my wood while I wasn’t looking. Fortunately, I see damage only in the sap wood – the heart wood seems to be untouched at this stage. I realise that I need to use some probably pretty nasty chemicals to kill off these invaders, and prevent further losses, but I’d like to also not stain or damage the wood by using the wrong stuff.
I know many LJs use felled or found wood in their projects, and am hoping that someone here can advise me on the best chemicals to use.
Thanks in advance.
p.s. here is a look at the wood I found inside a very ugly log.
Very Lacy.
12 replies so far
View joey502's profile
joey502
540 posts in 1598 days
#1 posted 12-22-2017 01:39 PM
Is wood that has or had termites worth trying to clear up? I do not know I would take the risk of bringing the bugs inside with the wood.
You could research timbor, bora care and borasol and determine if that is an option for you.
View fuigb's profile
fuigb
495 posts in 3037 days
#2 posted 12-22-2017 02:17 PM
Dude, you’re in South Africa. African termite mounds are as tall as some our houses. Abandon all hope, and take up metal-working. Ha. Seriously, I hope that you figure this out because that sample is the bomb.
-- - Crud. Go tell your mother that I need a Band-aid.
View Aj2's profile
Aj2
1576 posts in 1878 days
#3 posted 12-22-2017 02:53 PM
Remove the bark see if that helps. The wood looks a lot like the live oak we have around here very nice color you have there.
-- Aj
View HorizontalMike's profile
HorizontalMike
7769 posts in 2994 days
#4 posted 12-22-2017 03:04 PM
- joey502
+6 on Timbor.
FYI, I treated a large number of cut blocks with it and placed them in a covered trash can for 3yr. When I removed the wood, I only found ONE active beetle. In other words, if you can, have the wood kiln dried. The heat will kill the critters deep inside the wood.
Removing the bark DOES help, but does not eliminate completely.
View gargey's profile
gargey
1013 posts in 855 days
#5 posted 12-22-2017 03:18 PM
That’s an oak? Or is silver oak not a species of oak?
View John Smith's profile
John Smith
1229 posts in 242 days
#6 posted 12-22-2017 03:23 PM
I harvested a LOAD of grenadillo wood when I was in Guantanamo Bay, Cuba with the Navy.
after I got it home, bugs started chewing on the bark – probably powder post beetles.
fortunately, I had a chest freezer that was not being used. froze those little buggers to death LOL.
not much a person can do about chewing varmints other than heat or freeze.
if the freezer is not an option, put the wood in a metal drum and build a fire around it to bake it.
careful not to get it too hot to ruin the wood – just kill the bugs. no harsh chemicals involved.
if you are in a real buggy area, this may be an on-going problem.
a powder bug killer such as “Sevin” would be the preferred less invasive treatment.
it does not soak into the woodfibers like a liquid would.
-- Graduated Valedictorian from the University of HardKnocks --
View bondogaposis's profile
bondogaposis
4889 posts in 2431 days
#7 posted 12-22-2017 03:34 PM
The best protection is to slice it into boards right away and get it dry.
-- Bondo Gaposis
PG_Zac
#8 posted 12-22-2017 04:05 PM
That s an oak? Or is silver oak not a species of oak?
- gargey
Hey Gargery.
To Quote from Wikipedia:
“Grevillea robusta, commonly known as the southern silky oak, silk oak or silky oak, or Australian silver oak, is the largest species in the genus Grevillea of the family Proteaceae. It is not closely related to the true oaks,”
And
“It is a fast-growing evergreen tree, between 18ā€“35 m (59ā€“115 ft) tall, with dark green delicately dented bipinnatifid leaves reminiscent of a fern frond. It is the largest plant in the Grevillea genus, reaching trunk diameters in excess of 1 m (3 ft).”
The trunk diameter on this tree was close to 3 ft at the base
John Smith
#9 posted 12-22-2017 05:51 PM
wow – Zac. that is a LOT of beautiful lumber if you have the whole tree !
my recommendation for the heat treatment and powder insecticide was only
for the small pieces in your photo.
if you have the whole tree – or most of it – it would be best to slice and kiln dry
as discussed above. awesome things can be made from that tree !!
it would be a crying shame if it was ruined by bugs for sure.
View avsmusic1's profile
avsmusic1
273 posts in 765 days
#10 posted 12-23-2017 12:31 AM
- John Smith
Does freezing work? Iā€™m in CT where just leaving it outside this time of yr does that for free.
View Bob5103's profile
Bob5103
93 posts in 913 days
#11 posted 12-23-2017 02:29 AM
Is Borax https://www.amazon.com/Borax-Mule-Team-Detergent-Booster/dp/B000R4LONQ available where you live? I use it to protect my outdoor wood storage. Make sure your wood is off the ground (stacked on pallets) sprinkle a 6” border around the stack making sure there are no breaks in the border. You can also sprinkle it over the wood and tarp, without harming the wood. It has worked well for me.
John Smith
#12 posted 12-23-2017 02:33 AM
well – I think that you guys Up Nawth have bugs that are acclimated to
below freezing temps. because every summer, they are back.
I was bringing bugs from Cuba – which have never even seen a frost.
so a few days at minus 10 degrees did them in.
if you try the freezing thing, I am thinking the temps must be a prolonged
exposure to minus 20 for an extended amount of time. only thing you can do is experiment like I did.
I am a carpenter – not an entomologist.
Borax works on a lot of bugs – if they eat it. if they don’t eat it, nothing happens and you will still
have a bug problem. Borax works on the intestinal tract – not absorbed through the skin like other pesticides.
when I had some bee hives, I would sprinkle some around on the ground to keep out unwanted pests
as well as mixing it 50/50 with sugar and put in jar lids for ants.
but – they have to eat it for it to work.
