Gluing old growth redwood for coffee table.
Forum topic by longboarder posted 03-10-2011 11:33 PM 5015 views 1 time favorited 7 replies Add to Favorites Watch
View longboarder's profile
longboarder
29 posts in 3259 days
03-10-2011 11:33 PM
I have been commissioned to build a coffee table out of recycled redwood. This redwood is from old wine vats, 2” thick and absolutely gorgeous!! It’s very dry. I have not worked with redwood in furniture before. I have systems three epoxy which I work with in building boats but not sure if this is overkill. What do you guys and gals think. Thanks for any input! Oh yeah, you can smell the wine in these pieces, quite cool!
7 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 2844 days
#1 posted 03-11-2011 01:34 AM
If you’re talking flat grain joints, yes, the epoxy is overkill. Yellow will suffice nicely. Much easier in every way, and no compromise in strength.
Kindly,
View Sawkerf's profile
Sawkerf
1730 posts in 3062 days
#2 posted 03-11-2011 02:19 AM
Since redwood is usually pretty dark, I like a dark glue such as Titebond III or the brown carpenters glue. Yellow or white glues can sometimes show up.
Hopefully, you know that redwood is extremely soft. Be careful when sanding it.
When I do redwood projects, I like to use a flat or satin poly finish to give surfaces as much durability as possible.
View bandit571's profile
bandit571
19956 posts in 2677 days
#3 posted 03-11-2011 04:42 AM
J
ust normal yellow glue will work. This “TV Table” was made from an old Redwood pin-nic table’s parts.
View Dandog's profile
Dandog
250 posts in 2768 days
#4 posted 03-11-2011 04:54 AM
as Redwood is very soft .As long as the tables not going to be into a lot of direct sunlight. I think that clear epoxy is in a bad finish it all. But as far as just gluing the boards together carpenters glue is all you need.
-- life an woodworking is one big experiment
View therookie's profile
therookie
887 posts in 2821 days
#5 posted 03-11-2011 05:00 AM
I concur with lee
-- http://aewoodworks.webs.com
Sawkerf
#6 posted 03-11-2011 06:23 AM
This is a table top I made for a customer a couple of years ago. The redwood was old deck boards which I cleaned up and re-milled. The customer designed inlay is maple. The finish was three coats of Minwax Polycrylic.
View John Ormsby's profile
John Ormsby
1285 posts in 3731 days
#7 posted 03-11-2011 06:47 AM
I also think Titebond III would suit you best. I have worked with tens of thousands of BF of Redwood through the years and have had very good result with it. And, as has been stated already, it is dark which will go well with Redwood.
-- Oldworld, Fair Oaks, Ca
