Plywood Edging
Forum topic by HallTree posted 219 days ago 161 views 0 times favorited 4 replies Add to Favorites
View HallTree's profile
HallTree
563 posts in 254 days
219 days ago
Topic tags/keywords: tip
Just heard of a new, to me, way to edge plywood. Has anyone done this? Cut off a 45 degree strip from the edge. Cut off another 45 degree strip. Glue back on the first strip.
-- Ron in Osseo, Minnesota
View Rich_S's profile
Rich_S
54 posts in 352 days
219 days ago
I too have heard of it but haven’t done it. I envisioned a couple of potential problems with this approach and haven’t been brave enough to give it a go (such as keeping the edge properly registered to the main piece during clampup, have the veneer on the ply edging damaged during use or finishing). I can see some benefits of doing this with certain furniture designs where the corner of the 45/90 wouldn’t experience a lot of abuse and one was trying to maintain continuity around the for asthetic purposes. The approach is probably better than using the ultra thin heat activated veneer edging.
-- Rich, Madison WI
View Justin's profile
Justin
36 posts in 244 days
219 days ago
The problem with that is when you put the two miters together there is no room for sanding because the plywood veneer is so thin. I have not had good luck doing it that way, but I am sure others have.
Justin
View mike02719's profile
mike02719
20 posts in 273 days
219 days ago
Justin is right. The veneer is so thin, sanding leaves unsightly marks. I glue a strip of like species solid wood to the edge. If the piece is going to be exposed to a lot of stress, add biscuits. This process is time consuming, but well worth it.
-- Mike, Massachusetts
View rikkor's profile
rikkor
7687 posts in 361 days
218 days ago
I proceed like Mike above. I usually like an ogee or a round-over, so I need the material.
-- Maplewood, MN
Bookmark And Share This Page
