| Forum topic by IppoJ | posted 806 days ago | 4575 views | 3 times favorited | 15 replies | ![]() |
806 days ago |
The throat of the Ridgid R4512 is apparently designed to use only the included steel insert, as such the ears that hold the leveling screws are designed for material ~3/32”. I was hoping to get some expert experience to weigh in, will laminated MDF hold up to the task? I have some 1/2” mdf that I was going to laminate then route reliefs for the five leveling ears. Or, is there a better alternative? |
15 replies so far
#1 posted 806 days ago |
I have the Craftsman 21833, which is essentially the same identical saw with a different paint job. (I’m afraid that MDF made thin enough to sit on the ledge and leveling screws would be way too thin to support the work load.) I made my own insert using 10 ga aluminum plate. I traced the steel plate onto the aluminum with a scribe and cut it out with a jigsaw. It fits, and is strong enough to replace the steel plate. Starting with the blade in the lowest position I placed the blank insert in the table recess. Then clamped a 2×12 board to the table top, on top of the blank aluminum plate to hold it down as I cranked the saw blade up to its higest position; thus cutting a zero clearance slot. I used the crappy blade that came with the saw for this operation so I wouldn’t risk messing up my good blades. After I was done I ran a thin abrasive cutoff type blade along the slot with an angle grinder to give just a little relief. I then drilled 4 holes around the edges into which I epoxied 4 thin, rare earth magnets to hold the insert in place. The magnets need to be about .100” thick so they don’t protrude above the plate surface. I’m not suggesting anyone else try this method, it’s just how I solved my problem. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#2 posted 806 days ago |
crank, I honestly thought about doing the same thing but was worried about the coating on my blades, even after opening the slot up a bit. I also thought about making a dado sized insert from alum or steel and fitting a wood insert into the opening. Can I ask where you bought the aluminum stock? |
#3 posted 806 days ago |
I’m not sure if the 4512 insert is close to the 3650, but what I did was take some 1/2” MDF and use a straight bit in my router to clear out a section where the ears are. I just took a little off on each pass until it would sit flush. Like this: You can see more pictures here: http://fattoad.smugmug.com/Woodworking/Stuff-for-the-Shop/Zero-Clearnce-Insert/15696570_K2292 -- David |
#4 posted 806 days ago |
David, the 4512 is nothing like the 3650, cept maybe the color scheme. The insert sits on a tiny ledge that’s about 1/8” wide and about 1/8” below the table top. The bosses for the leveling screws stick out about 1/2” in 4 places. If you had to machine out the MDF like you show in your pictures, you would have to keep cutting till the edges were less than 1/8” thick. IppoJ, I used to work for a contractor who also has a fabrication shop and steel yard. I bought it from them. You can usually buy aluminum from a steel yard. A good mail order supplier is McMaster Carr. I forgot to mention that when you drop the blade all the way down its not quite low enough to put the blank insert in the slot without contacting the blade. I had to install a 7 1/4” blade I had laying around to start the slit. Then I switched to the 10” blade to finish. I think the “insert in the insert” idea would work just fine. One other point I would like to make. I think this saw would benefit from blade stabilizers so I bought some. Now if I install the stabilizers (thick, oversize washers) that better support the blade, none of my jigs, sleds, or inserts will fit because the blade position moves about 1/4”. :-( -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#5 posted 805 days ago |
crank is correct, the distance from the table top to the ears is less than 1/8”. I have a sheet of phenolic/linen that would be perfect and is the correct thickness but the piece I have isn’t long enough. |
#6 posted 726 days ago |
These are now available for the r4512: I don’t think I’ll be fabricating these. -- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia |
#7 posted 726 days ago |
I made mine out of http://www.ptreeusa.com/uhmwproducts.htm a plastic. |
#8 posted 726 days ago |
I forgot to say I routered out a slot for the arbor as the 3/8”is a little to thick. I had made some inserts out of 1/4” plywood but the plywood shattered when trying to cut thin strips of
red oak.The insert between the blade and fence flexed to much, not enough support because I had ordered 2 sheets of the plastic. The cost was about $48.00 with shipping. I still have to extend the slot on the zero clearance insert for the riving knife. |
#9 posted 726 days ago |
Sounds like the 4512 uses thin inserts like my TS2400. Here is a tutorial I made about ZCIs for it made from 5/16 laminate flooring. http://www.hoistman.com/HoistMan/ZCItute.html -- Carpenter assembles with hands, Designer builds with brains, Artist creates with heart! |
#10 posted 724 days ago |
Don’t ya just love it that people who design equipment don’t ever actually use it? -- When the moderator chooses sides, his site sucks. |
#11 posted 723 days ago |
Leecraft inserts He has them all. |
#12 posted 723 days ago |
Check out my Insert !!! More Pict’s under my projects -- Pat - Worker of Wood, Collector of Tools, Father of one |
#13 posted 367 days ago |
I bought the zero clearance dado insert from woodcraft.com and it wouldn’t even go down on my R4510 at all. Had to return it. I think the seperator knife was in the way. And since I recently purchased the R4510 I don’t think I want to begin removing parts just to get a new part to fit that didn’t come with the tool. Guess, I’ll be making one from wood as I did with my old craftsman. It worked fine when I used it. -- May you always believe in the magic! |
#14 posted 367 days ago |
I’ve made several ZCI throat plates for my R4512 using 1/8” hardboard. They fit perfectly and provide more than adequate support. A 1/4 sheet from the borg costs only a few bucks and there’s enough material to make seven or eight inserts. -- John, BC, Canada |
#15 posted 365 days ago |
popeye, I think the R4510 throat is a lot different than the R4512. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15807 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
