Cabinets for home salon
Forum topic by Southsider posted 12-21-2017 07:40 AM 366 views 0 times favorited 7 replies Add to Favorites Watch
View Southsider's profile
Southsider
10 posts in 331 days
12-21-2017 07:40 AM
Topic tags/keywords: cabinet question toe kick euro frameless base
Hello all,
I want to thank everyone in advance for any tip and info, I have already been learning a ton of stuff from reading posts by all the members here.. So here’s my question.
I am getting ready to build two base cabinets for a home salon for my wife. I’ve decided to go with the frameless euro style cabinets (wife’s choice actually). The cabinets will be identical, each 36” wide, but there will be a roughly 30” gap between them to allow her salon chair to be moved in close to the countertop. I will be installing them in the basement on a concrete floor. Do I need to run stretchers on top or across the backs connecting these two cabinets to each other?
Also my initial plan was to build separate toe kicks so I could more easily level them and set the bases on top, but how will I connect the already assembled cabinets to the toe kick?
Sorry if these are Day 1 questions you guys hear all the time, but this is my first time building cabinets and it’s a bit overwhelming!
Thanks again
T
7 replies so far
View Loren's profile
10477 posts in 3727 days
#1 posted 12-21-2017 07:59 AM
I don’t think you need stretchers but I would
screw the cabinets to the countertop.
Many frameless custom cabinets are installed
using plastic leveler legs. The toekick is an
applied panel that clips to the front pair of
levelers. You can put a toekick on the insides
too using the clips, or put on an applied end
which gives a full overlay door kind of an inset
look. The applied end looks nicer imo.
View jdh122's profile
jdh122
1031 posts in 2897 days
#2 posted 12-21-2017 11:02 AM
If you don’t want to use the plastic legs you can just build square frames out of construction lumber. Level the frames with shims and attach them to the floor (with a couple of tapcons in your case) or wall. Then screw or pin the cabinets to them from inside the cabinets. And then apply toekick by pinning it to the frame.
-- Jeremy, in the Acadian forests
View Mike_D_S's profile
Mike_D_S
482 posts in 2294 days
#3 posted 12-22-2017 12:10 AM
If you want to use separate toe kicks, you can install triangular gussets in the corners of the base so you have an easy place to run a screw into to mount the base cabinets.
Mike
-- No honey, that's not new, I've had that forever......
View cabmaker's profile
cabmaker
1738 posts in 2888 days
#4 posted 12-22-2017 12:55 AM
Under ideal circumstances…..you would not build any type base for this use
cabinets would mount to the wall…leaving approx 8-10 of clear space to aid in cleaning, mopping, sweeping
View skatefriday's profile
skatefriday
420 posts in 1562 days
#5 posted 12-22-2017 02:35 AM
Bob Lang describes separate toe kicks in his book. I built mine that way and I think it really helped to level the toe kick before putting the cabinet on.
Mike_D_S
#6 posted 12-22-2017 04:57 AM
I wasn’t really thinking ‘salon’ when I read it the first time, but given the need to clean up, I agree with cabmaker that leaving them off the floor mounted to the wall is probably the best approach from a cleaning/maintenance perspective.
Mike
View AlaskaGuy's profile
AlaskaGuy
4264 posts in 2388 days
#7 posted 12-22-2017 05:03 AM
Deleted
