Plane irons: flat or curved
Forum topic by Brett posted 03-10-2011 12:22 AM 849 views 0 times favorited 2 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2709 days
03-10-2011 12:22 AM
I’ve noticed that some plane irons are ground with a straight cutting edge and others with a very slight curvature. Also, some irons have their corners rounded and other do not. What are the reasons for these differences, and how would I decide which way to grind an iron for a particular plane or application?
-- More tools, fewer machines.
2 replies so far
View Bill White's profile
Bill White
4949 posts in 3987 days
#1 posted 03-10-2011 12:27 AM
Rounding the edges of irons help reduce the tendancy of the iron to “dig in” on the edge of the cut. The radius gring is mostly used on jack (#5 usually) planes used to quickly reduce the surface of the workpiece. This cut will leave some very shallow grooves that are then removed by a smoother like a #4.
Hope this helps.
Bill
-- bill@magraphics.us
Bill White
#2 posted 03-10-2011 12:28 AM
Ooops!! That should read GRIND not gring. Duh!
Bill
