**UPDATE** inventors?? i need help !!
« back to Coffee Lounge forum
Forum topic by GR8HUNTER posted 12-20-2017 09:29 PM 2175 views 0 times favorited 38 replies Add to Favorites Watch
View GR8HUNTER's profile
GR8HUNTER
5130 posts in 914 days
12-20-2017 09:29 PM
Topic tags/keywords: dp-220 help
might be impossible to do but i am looking for an easier way to move my DP table up and down i know floor models have like a rack with a turning handle not sure if that would work or not but i defiantly need help with this i guess getting older and shoulders and arms don’t work as they should thanks for all help :<))
38 replies so far
View Dutchy's profile
Dutchy
3149 posts in 2370 days
#1 posted 12-20-2017 09:37 PM
What about a simple (12V electric) jack below the table. Maybe a feather is needed for down movement.
-- https://dutchypatterns.com/
MrUnix
7049 posts in 2400 days
#2 posted 12-20-2017 09:44 PM
I’ve seen a lot of different ways that was accomplished. Some type of jacking system under the table like Dutchy suggested is one way… scissor jack, bottle jack, bumper jack, floor jack, etc. I have also have seen people use linear actuators turned vertical and wired with an up/down control panel. The old school machine shops would put a pulley on top of the column with one end attached to the table and the other to a hand crank mounted on the back/side of the press or even a winch to motorize it. Or you could get fancy, depending on your fabrication skills, and retro-fit a rack/pinion crank. Lots of ways to be creative :)
View Robert Keeney's profile
Robert Keeney
85 posts in 3714 days
#3 posted 12-20-2017 09:47 PM
View LittleBlackDuck's profile
LittleBlackDuck
2088 posts in 1022 days
#4 posted 12-20-2017 09:50 PM
Many years ago I bought a “Piric Easy Riser” that worked on a pulley system with a lead window sash weight travelling up and down the DP shaft. When I moved to variable speed, I lost access to the shaft so I don’t use it. If you want, you are more than welcome to pick it up from Churchill FOC.
Just in case you don’t have the time to fly over, here is a picture of it’s concept….
Now the product is no longer available so I’m guessing the pattents may be a mute subject.. If you want, PM me and I can upload the manual to DropBox and link you to it.
View Knockonit's profile
Knockonit
477 posts in 403 days
#5 posted 12-20-2017 10:04 PM
fulcrum and lever, make one you can set up real quick and dismantle as fast, unless you are doing the up and downs daily or mulitiple times.
good luck
rj
LittleBlackDuck
#6 posted 12-20-2017 11:10 PM
Take #2...
GR8HUNTER
#7 posted 12-21-2017 12:06 AM
sorry ducky take 2 wont work until i get a rack :<((
View lew's profile
lew
12430 posts in 3957 days
#8 posted 12-21-2017 12:26 AM
maybe you could build/buy a small one of these?
View Macrosill's profile
Macrosill
15 posts in 746 days
#9 posted 12-21-2017 03:01 PM
Maybe a long stroke electric actuator mounted to the bottom of the table and a lower location on the main shaft. Wired with a on/off/on momentary contact switch and you have an electric raising and lowering table. You would still have to tighten the table to prevent twisting.
-- Thanks, Brian
View moke's profile
moke
1268 posts in 2978 days
#10 posted 12-21-2017 05:41 PM
I have a floor model, but I went to harbor freight and got a hydraulic cylinder for a engine hoist. I rigged it under my table with large hose clamps and some spacers I cut on my band saw. It is awesome…better than a crank any day. Mine was a long stroke because of the height I needed, but I am sure you could find one right for your purpose.
I’ll give you more particulars if you are interested…....
I have been going to buy a new DP for years but I really like the way this works…
-- Mike
View pintodeluxe's profile
pintodeluxe
5798 posts in 3015 days
#11 posted 12-21-2017 05:43 PM
Yeah, Mike… Please post some pictures of your hydraulic cylinder setup. That sounds pretty nice.
View Woodknack's profile
Woodknack
12431 posts in 2581 days
#12 posted 12-21-2017 05:45 PM
A pulley and counterweight would be fairly simple and effective make the table weigh nothing. The Easy Riser system posted above is the idea although the weight could be exterior.
View robscastle's profile
robscastle
5482 posts in 2405 days
#13 posted 12-21-2017 06:56 PM
Tony,
There is only one answer.
Sell it and buy your self a new one.
We havent lived this long to have to put up with dinosaurs, its bad enough our bodies are that way and we cannot do anything about it however we we dont need our tools to be the same. Sell it and buy your self a new one.
Its almost Christmas and I betting your thinking about what you are going to buy eveyone else so add another name on the list! Sell it and buy your self a new one.
On the 26th I will be expecting to see just what you got, ...no excuses will be accepted !
BTW I have added a note in my diary to check on you later in case you forget to post the update.
Just in case you missed the hidden message Sell it and buy your self a new one.
That LPG lathe my be due for an update as well
Merry Cristmas Buddy!!!
-- Regards Rob
GR8HUNTER
#14 posted 12-21-2017 10:30 PM
Robert ….. send Santa my way i ask for one :<))
Mike ….i would like to see what you came up with :<))
MrUnix
#15 posted 12-21-2017 11:56 PM
- moke
There are a few members over at OWWM who have gone that route as well, and appear to be quite happy with the results. With a 20% off coupon, you can get it for less than $40. Here is a link to the cylinder: 3 Ton Heavy Duty Long Ram Hydraulic Flat Bottom Jack
showing 1 through 15 of 38 replies
