lettering on a small box
Forum topic by jerkylips posted 12-20-2017 05:27 PM 524 views 0 times favorited 10 replies Add to Favorites Watch
View jerkylips's profile
jerkylips
462 posts in 2774 days
12-20-2017 05:27 PM
I’m planning to make a small box for a friend – more of a gag gift than anything. I want something written on the top, not sure the best way to do it.
I thought about using adhesive letters, then staining with them on, peeling off to leave the unstained wood “letters”, then clear coating. I’m not sure if the stain would bleed through under the stickers, though.
Any thoughts?
10 replies so far
View wuddoc's profile
wuddoc
319 posts in 3922 days
#1 posted 12-20-2017 06:35 PM
You may wish to discuss your requirements with a sign or trophy shop that has a CNC laser. We use MS Word downloaded into our laser and it works very well for us.
-- Wuddoc
View LittleShaver's profile
LittleShaver
422 posts in 823 days
#2 posted 12-20-2017 06:56 PM
I usually get out the old wood burning pen and have at it.
I did recently see a video on several ways to transfer laser printed material directly on to wood. Looked easy and quick, but I haven’tr tried yet.
-- Sawdust Maker
View Walker's profile
Walker
150 posts in 676 days
#3 posted 12-24-2017 05:23 AM
Do you have a router? Use a small straight bit set to a fairly shallow depth and free hand it! Draw your pattern with pencil and then rout over the pencil lines. a 1/16” or 1/8” straight bit is actually pretty easy to keep true.
-- ~Walker
View Pompeio's profile
Pompeio
9 posts in 394 days
#4 posted 12-24-2017 02:34 PM
My wife recently painted some wood Christmas signs. She pencilled the letters onto the wood and then applied Gorilla-brand clear tape to the outlined border of the letters. She was then able to paint the letters without any of the paint getting beneath the tape onto unwanted areas.
Pompeio
9 posts in 394 days
#5 posted 12-24-2017 02:35 PM
Forgot to mention that she tried taping a stencilled template to the wood but the paint did get under it.
LittleShaver
#6 posted 12-24-2017 07:14 PM
There is a video on another website that demonstrates several ways to transfer laser printed materials to wood. Search YouTube for 5 ways to print on wood.
I tried the acetone method and it worked fairly well. I did it on white oak, I think it would do better on something with a tighter grain like maple.
-- Sawdust Maker
View Mengtian's profile
Mengtian
12 posts in 369 days
#7 posted 12-24-2017 10:26 PM
You could try wood burning. Pretty simple. You can get a decent starter kit for under 30 bucks.
View jeffswildwood's profile
jeffswildwood
3610 posts in 2181 days
#8 posted 12-24-2017 10:39 PM
I use a dremel with a router attachment
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View Jim Finn's profile
Jim Finn
2687 posts in 3126 days
#9 posted 12-25-2017 02:17 PM
I put lettering and images on small cedar boxes a lot. I inlay most (using a scroll saw) but I apply some. I print out what I want on my inkjet printer and glue it to the wood and apply wipe on poly over it. Many coats.
-- No PHD just a DD214 Website> craftingcouple.com
View Planeman40's profile
Planeman40
1307 posts in 2965 days
#10 posted 12-25-2017 04:20 PM
Two ways not mentioned . . . .
1. Use “press type” available from art supply stores. These are “decal like” in that they are very thin and have a adhesive on the back. Need to be protected with a couple of coats of clear varnish.
2. If you are handy with making graphics on a computer using a drawing program, make up anything you want and print out in color on thin writing paper. Cut out and color white edge. Glue onto wood with Titebond. Finish by applying two coats of varnish over graphic. (I have used this method to make “decals” to decorate delicate scale rubber-powered airplane models for years. Works better than you would have ever anticipated and has the appearance of true decals. Be sure to color the paper edges though.)
