whitch saw?
Forum topic by timbecht posted 12-20-2017 01:29 AM 592 views 0 times favorited 11 replies Add to Favorites Watch
View timbecht's profile
timbecht
13 posts in 2052 days
12-20-2017 01:29 AM
ok I have it narrowed down to two saws
ridige 4516
or kobalt
each has pros and cons just looking for advice on which one to go for
11 replies so far
View Holbs's profile
Holbs
2003 posts in 2227 days
#1 posted 12-20-2017 01:32 AM
no Bosch 4100 considerations?
timbecht
#2 posted 12-20-2017 01:42 AM
no have a tight budget
Holbs
#3 posted 12-20-2017 01:49 AM
Ridgid R4516 10 in. Portable Jobsite Table Saw
$335.52
Walmart
Factory Reconditioned Bosch 4100-RT 10 in. Worksite Table Saw
$349.99
Free Shipping
View knotscott's profile
knotscott
8146 posts in 3573 days
#4 posted 12-20-2017 07:13 PM
So need a portable saw? If budget is the primary reason for the two you’ve chosen, I’d look to the used market for a good full size contractor saw with a belt drive induction motor instead.
View MrUnix's profile
MrUnix
7038 posts in 2397 days
#5 posted 12-20-2017 07:39 PM
+1 to what Scott sez ^^^^
The plastic portable saws are great if you need to run from job site to job site for rough framing work, as long as you don’t push them too hard and melt the motors plastic housing. In a homeowner/small shop environment where that portability is not needed, you want something with a real motor. You can easily find a nice used saw for that kind of money and still have a lot left over.
timbecht
#6 posted 12-21-2017 01:30 AM
looked into that option but where I live used saw are mostly none present
View ohtimberwolf's profile
ohtimberwolf
871 posts in 2550 days
#7 posted 12-21-2017 01:44 AM
Here is the link from Holbs if you want to look at it. larry
https://www.cpooutlets.com/factory-reconditioned-bosch-4100-rt-10-in--worksite-table-saw/bshr4100-rt,default,pd.html?cgid=table-saws
-- Just a barn cat, now gone to cat heaven.
timbecht
#8 posted 12-28-2017 03:59 PM
if u had to chose which one of the two would you go with
View dbeck's profile
dbeck
65 posts in 557 days
#9 posted 12-28-2017 04:55 PM
I have the kobalt ts, if you want to know something specific about it i would be glad to help. I have run the hell out of it and it is still going. Never used the other one you asked about.
View Woodknack's profile
Woodknack
12430 posts in 2578 days
#10 posted 12-28-2017 07:25 PM
Save your pennies until you can afford something good enough for woodworking. Buy once, cry once.
Holbs
#11 posted 12-29-2017 01:24 AM
Tim.. I have to agree with Brad and Rick above. For $300-$400 range, a cabinet saw should come up on craigslist eventually, or some local auction. I bought my Delta Unisaw (3hp motor, 52” rails) cabinet saw for $500 off craigslist. And my Powermatic 66 for $150 at a local auction. I rarely use my Bosch 4100 contractor/portable saw, except to work with MDF outside. I keep it “just incase” because it is a fantastic saw for how small it is.
