Warped plywood
Forum topic by WoodNuts posted 03-09-2011 12:22 PM 3140 views 0 times favorited 7 replies Add to Favorites Watch
View WoodNuts's profile
WoodNuts
74 posts in 2915 days
03-09-2011 12:22 PM
Looking for your techniques on how you straighten warped Baltic Birch plywood in any size > 20”sq.
Thanks for any/all replies…
-- ...there's a fix fer dat...
7 replies so far
View CampD's profile
CampD
1653 posts in 3453 days
#1 posted 03-09-2011 02:34 PM
Baltic birch is the most stable ply I know, must have picked up a LOT of moisture to warp.
You can try and stack it flat with a lot of weight of top and time will tell
-- Doug...
View Sawkerf's profile
Sawkerf
1730 posts in 3035 days
#2 posted 03-09-2011 04:55 PM
I would either start over with a better grade of ply, or assemble your warped pieces so they get straightened out – and hope that the additional stresses relieve themselves without wrecking whatever you’re buildig.
Rick Dennington
5807 posts in 3161 days
#3 posted 03-09-2011 05:10 PM
Greetings Woodnuts,
The best way I’ve found to help warped ply is to WET it down really good all over....anything up to a 4’x 8’.
Take a rag, soak it in water, and wipe the ply down good on both sides….... Lay it down flat, and stack more ply on top of it to keep it flat…..if you have an extra sheet or two….
  • If not, weight it down the best you can with something heavy like cauls and clamps….cinderblocks, etc….* Let it dry really good for a couple of days and check it…..if flat and weighted, it should be straight….
    After it’s dry, use ASAP…....I’ve done it a 1/2 dozen times….works for me….....hope this helps.
View Will Mego's profile
Will Mego
307 posts in 3679 days
#4 posted 03-09-2011 07:42 PM
yeah, I think that the odds aren’t with you, but the only decent way is like Rick said, wet BOTH sides well, then clamp, stack, whatever to get it flat and straight…think of it as cold steam bending in a way. Good luck though!
-- "That which has in itself the greatest use, possesses the greatest beauty." - http://www.willmego.com/
View Mike Gager's profile
Mike Gager
665 posts in 3234 days
#5 posted 03-10-2011 08:00 PM
if the piece you are using wont be seen in the final product, such as an interior panel or even if only one side will show you can cut relief kerfs on one side of the panel, that should flatten things out
similar idea to kerf bending plywood except you are trying to take the bend out
View Bill White's profile
Bill White
4906 posts in 3927 days
#6 posted 03-13-2011 08:12 PM
A really hot fire will solve the problem. Get it roaring, then throw the crappy plywood on top. Step back, get a beer, and watch out for any stray sparks.
Bill
-- bill@magraphics.us
View jusfine's profile
jusfine
2422 posts in 2892 days
#7 posted 03-13-2011 08:22 PM
I had some BB stored for a couple years and it was quite warped too, but it was in the shop and didn’t get any moisture on it.
I ended up buying new full sheets and cutting the other warped sheets up for smaller pieces. Still caused me some grief with my outfeed table construction.
All the Best!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
