Name that tool
« back to Hand Tools forum
Forum topic by lumber_jerk posted 12-19-2017 01:09 AM 1083 views 0 times favorited 19 replies Add to Favorites Watch
View lumber_jerk's profile
lumber_jerk
17 posts in 753 days
12-19-2017 01:09 AM
Topic tags/keywords: mystery tool handtool gobbledy-goo
egg-beater crank style slotted “business end” cast iron crank & shaft, but cast brass handle/housing? **here’s the big mystery-
-3 sets of teeth on main gear —each set with a different amount of teeth (5, 6 & 7)
2 turning gears (top & bottom) alternate the direction of the shaft…back and forth-ish….but of course, since the teeth are uneven, it ultimately advances…maybe?...forget my description….please see pictures
19 replies so far
View Loren's profile
10477 posts in 3883 days
#1 posted 12-19-2017 01:12 AM
You have to upload, then insert pictures on
Lumberjocks. It’s a 2-step process.
lumber_jerk
#2 posted 12-19-2017 01:15 AM
View 000's profile
000
2859 posts in 1134 days
#3 posted 12-19-2017 01:16 AM
hand powered hammer drill
View JohnMcClure's profile
JohnMcClure
393 posts in 875 days
#4 posted 12-19-2017 01:18 AM
Is it possible this was once a kitchen implement? The reciprocating action seems like it would be more desirable in… well… an eggbeater…
-- I'd rather be a hammer than a nail
#5 posted 12-19-2017 01:36 AM
Thing for driving a thread tap maybe?
lumber_jerk
#6 posted 12-19-2017 01:42 AM
Each gear is not engaged at the same time…top always one way, bottom the other…and the crank only likes to turn in one direction- because of the 5/6/7…idk, I ain’t mathemortition!
JohnMcClure
#7 posted 12-19-2017 01:53 AM
I like the tap idea.
lumber_jerk
#8 posted 12-19-2017 02:37 AM
I liked the hammer drill idea, but I can’t find any photo confirmation, and thin bit kerf makes no sense to me…. my cousin’s boyfriend thinks the gear teeth may have been ground down
JohnMcClure
#9 posted 12-19-2017 02:49 AM
If the larger wheel had been fully toothed all around (and subsequently ground down), it wouldn’t have turned – the teeth at the top would have tried to drive the top cog clockwise, while the teeth at the bottom would have tried to drive the bottom cog counterclockwise.
If the teeth really were ground down to the current configuration, perhaps the two cogs had formerly had some ability to to be moved in or out of contact with the drive wheel one at a time.
Paint mixer?
View 000's profile
000
#10 posted 12-19-2017 02:54 AM
^paint mixer sounds about right.
runswithscissors
2920 posts in 2260 days
#11 posted 12-19-2017 04:02 AM
If it had a rubber suction cup at the business end, I’d say it was a tool for lapping valves in a flathead engine. I know that a tool for that purpose does (or used to) exist.
View bigblockyeti's profile
bigblockyeti
5310 posts in 1955 days
#12 posted 12-19-2017 05:12 AM
I wonder if it’s really (really) old, perhaps it’s to drive a bidirectional spoon bit?
View bold1's profile
bold1
310 posts in 2082 days
#13 posted 12-19-2017 11:56 AM
Valve lapper. Last one I saw listed on the web the guy was asking $100. Don’t know if anyone would give that for it or not.
View Tennessee's profile
Tennessee
2893 posts in 2749 days
#14 posted 12-19-2017 01:43 PM
+1 for the valve lapper.
lumber_jerk
#15 posted 12-19-2017 08:31 PM
Awwwe, a mechanic’s tool? Great! Now my truck has valves…..She’s probably unlapping ‘em all right now. I ain’t got time for this nonsense…. paint-mixer it is
