Which CA glue for natural edges?
« back to Woodturning forum
Forum topic by David Smith posted 12-18-2017 12:06 PM 509 views 0 times favorited 9 replies Add to Favorites Watch
View David Smith's profile
David Smith
43 posts in 713 days
12-18-2017 12:06 PM
I’m new to woodturning after 4+ decades of being a “square woodworker” and I discovered how much I enjoy natural edge bowl turning. I have a question about CA glue that I didn’t find an answer to in previous forums (if this has been discussed already, let me know).
I know that CA glue is good for shoring up the bark. Which is best: thin or medium CA glue? I used medium on my first natural edge bowl, but it seemed gummy looking. Will thin CA glue give a more natural look?
Thanks in advance for your responses.
-- David
9 replies so far
View Tennessee's profile
Tennessee
2893 posts in 2715 days
#1 posted 12-18-2017 12:53 PM
I would use thin CA. It will penetrate much deeper. You probably will use quite a bit, depending on the amount of bark.
Remember though, that CA excels in its static strength, not its dynamic strength, so it would still break if hit. It also should put a bit of a shine into the bark.
That shine is why it is the overwhelming choice as a finish by penmakers.
View Bill7255's profile
Bill7255
428 posts in 2486 days
#2 posted 12-18-2017 01:17 PM
Thin. I put shellac below first ti keep,the CA from bleeding into the wood
-- Bill R
View John Smith's profile
John Smith
1482 posts in 364 days
#3 posted 12-18-2017 03:13 PM
when one works with CA glue on a regular basis, it is a good idea to keep
a bottle of ” CA Debonder ” close by….. just in case you get your fingers
stuck to your – - – ear or something. There are several brands available.
-- I started out with nothing in life ~ and still have most of it left.
David Smith
#4 posted 12-19-2017 10:58 AM
Very helpful advice. Thanks.
By the way, what’s a good source for CA glue in bulk?
-- David
Tennessee
#5 posted 12-19-2017 01:44 PM
Probably the cheapest I have seen in bulk is on Amazon.
View lew's profile
lew
12428 posts in 3956 days
#6 posted 12-19-2017 04:05 PM
By the way, what s a good source for CA glue in bulk?
- David Smith
Starbond
View Wildwood's profile
Wildwood
2475 posts in 2336 days
#7 posted 12-19-2017 08:45 PM
When wood havested in winter sap not running bark supposed to stay on without any glue. Nice rule of thumb but not always the case. I think any CA glue medium or thin you find will do a good job for you just buy what you find locally.
You want the freshest CA can find due to recommended 2 year shelf life by manufacturers. Not sure ever seen a date on the stuff, but my eyes are old too.
-- Bill
Tennessee
#8 posted 12-19-2017 09:03 PM
I have found that temperature changes in your shop can affect CA more than time. They both take a toll, but I lost a lot of CA last winter when I let my shop hit 40-45’.
View MrUnix's profile
MrUnix
7046 posts in 2400 days
#9 posted 12-19-2017 09:44 PM
I always use poly instead of CA glue… mostly because it’s way less expensive, and that is typically what I finish the pieces with anyway, so I always have some on hand. Thinned 50/50 with MS and let it soak in. Of course, regardless of what you use, you still need to have that ginger touch around the bark when turning to keep it from catching and throwing off a chunk or two :) Good sharp tools help with that more than anything else. I’ve been doing a lot of spalted live edge crotch bowls lately, and those can be a bit touchy.
