A Weighty Question
Forum topic by Deadend posted 12-17-2017 09:25 PM 498 views 0 times favorited 6 replies Add to Favorites Watch
View Deadend's profile
Deadend
15 posts in 453 days
12-17-2017 09:25 PM
Topic tags/keywords: question
Posted this in wrong forum before.
I’ll try it here.
Rating these heaviest to lightest how would you list the following?
All will be the same size and 3/4” thick.
1. Birch plywood 2. Melamine 3. MDF
Thank you for your time.
—You’re never late until you get there.
-- You're never late untill you get there.
View Dan Krager's profile
Dan Krager
4230 posts in 2474 days
#1 posted 12-17-2017 10:52 PM
2,1,3.
What did I win? :)
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com Now there's a face that would stop a clock! And seriously mess with small watches.
View jonah's profile
jonah
1972 posts in 3538 days
#2 posted 12-17-2017 11:48 PM
Solid melamine, or melamine faced particle board? If the latter, it’s 3, 1, 2 I think.
View Loren's profile
10477 posts in 3887 days
#3 posted 12-17-2017 11:53 PM
Melamine and MDF are pretty close in weight.
About 90 lbs a sheet I think.
Hardwood ply tends to be around 60 lbs give
or take. I’ve bought it with a couple of layers
of 1/8” MDF in it, which makes it more stable
but a little heavier.
Sometimes 5/8” melamine is available which
is lighter. Ultra-light MDF is available too. I
prefer it just because it’s so much lighter but
it seems more prone to warping.
Deadend
#4 posted 12-19-2017 02:08 AM
I thought this would be a tough question and it was.
Out of three responses two rated MDF heaviest and two rated Ply as #2. Each material got a vote as the lightest. Melomine was picked 1 2 and 3. Interesting…
I’m planning an extension wing and a drop down outfeed table for my new Ridgid 1245.
With the “improved” three castor system the beast can be tippy even on a smooth surface. Thus the weight concern.
I don’t think a small amount of either material will alter the movement that much.
I have seen 5/8” melomine. That may be the answer.
Again, Thank you for you time.
View jmos's profile
jmos
905 posts in 2609 days
#5 posted 12-19-2017 01:19 PM
A little googling will give you some weights, like here
As mentioned, it rather depends on what type of melamine and plywood your looking at.
-- John
Deadend
#6 posted 12-19-2017 02:48 PM
John,
Thanks for the link to a VERY useful site.
