Glider bearing help
Forum topic by Rs12474 posted 12-17-2017 05:24 PM 443 views 0 times favorited 3 replies Add to Favorites Watch
View Rs12474's profile
Rs12474
1 post in 398 days
12-17-2017 05:24 PM
need help locating a source for glider bearings. I have searched all the online suppliers i can find and nobody has the size i need. They are a 7/8 OD flange bearing with a 7/16 non threaded center. There is no manufacturer tag on the chair anywhere. Anyone have any ideas where i might be able to find them?
3 replies so far
View diverlloyd's profile
diverlloyd
3282 posts in 2094 days
#1 posted 12-17-2017 05:40 PM
https://www.amazon.com/Glider-Rocker-Bearings-Set-8/dp/B00T0RWMX2
http://www.ebay.com/bhp/glider-bearings
Not sure if you just want a bearings or all the hardware. The top link you could bore the center hole out.
View Loren's profile
10477 posts in 3885 days
#2 posted 12-17-2017 07:53 PM
Grainger is a great source for stuff like that.
View wuddoc's profile
wuddoc
322 posts in 3955 days
#3 posted 12-17-2017 08:48 PM
McMaster-Carr like Grainger as indicated by LJ Loren can also be a source. I have attached a page from McMaster but if it is not correct give McMaster or Grainger sales a call. I have found they will do the research for you. Both will sell small quantities if possible.
https://www.mcmaster.com/#standard-ball-and-roller-bearings/=1aq6snt
-- Wuddoc
