Good evening…I've not been on here in a long time and I hope this is the appropriate place for this. I am building a new workshop and want to upgrade my SS Prof 3 HP to the 5 HP. You are right…I likely don't need to do this but it's already in my head. It works perfectly and I've taken great care of it. The iron top is in great shape no dings…there is some surface rust on the ruler part but otherwise it's all good. I'm open to discussion of price…we all know purchase price is around $2800ish…I"ve had it for about 5 years I think…so I'm open to pricing. I'm in SW Georgia so not sure about transport. Thanks for any interest out there.
Hi Josh. A new tool is always nice. Especially in a new shop! However, in my opinion, unless unless you are planning going professional or taking on some heavy duty projects, 3hp should be more than adequate.
I'm in no way trying to tell you what to do, but perhaps the money saved could get you into a better…..(fill in the blank). In the end you know where best to invest your money. Either way, I wish you the best and envy your getting a new shop.
I agree…but you are being logical about this. Just kidding, I completely understand and that was the plan until just recently…we'll see. I'm basically wanting the new SS stuff…3 phase with router table built in…that's the main reason I'm looking. Certainly the 3 hp is plenty for me as a weekend warrior woodworker…
I went with a friend several months back to look at a used 3 hp SawStop Professional saw he wanted to check out that was listed on craigslist. It was in mint condition, had the built in wheeled base and the overhead dust collector. If I remember correctly the owner said he had it about 6 years. It didn't look as if it has seen much use. He ended up paying $1600 cash for it.
I agree…but you are being logical about this. Just kidding, I completely understand and that was the plan until just recently…we ll see. I m basically wanting the new SS stuff…3 phase with router table built in…that s the main reason I m looking. Certainly the 3 hp is plenty for me as a weekend warrior woodworker…
Sounds to me like you just want to waste money..Be wise with your money. The only time I seen a 3hp give is when the blade was real dull or they forced it.
Maybe a wise assortment of quality blades would get the added hp off your mind….
Personally, Josh, I like the way you think. If I may make a suggestion. Before treating yourself to a new SS with all the bells and whistles, I think you should get yourself a new full size Ford F-150 pickup truck to haul it home in. After all, a saw like that deserves the very best in luxury transportation to your new shop!
In all seriousness, I get it…it can be viewed as not necessary…certainly it is not. I am frugal on most things…but on certain hobbies I am willing to spend a bit. This isn't a 2nd home or a vehicle and I'm looking to recoup at least some from my current saw…hoping someone who otherwise wouldn't get to use/enjoy a ss may now have the chance and then I can also get what I want (not what I need). I am also building a new workbench, miter bench, tablesaw table…I could also save the existing one or modify it, but I've learned more since that build and want to do things differently. It could be viewed as wasteful but it is a passion of mine while I"m certainly an amateur compared to most of you…but I enjoy it and want to do more.
I agree…I'm not sure exactly what to ask but certainly not expecting what I paid for it. As noted above, I would think around $1600 would be fair to both parties…the bigger issue would be the buyer would almost have to be local to make it worth getting as it would cost a fortune to ship. I can move/load it with my forks on my tractor.
I'm guessing you can get closer to $2k. Put it on Craigslist and it will probably be gone before nightfall. You don't see too many SS show up for sale.
Hey, you only live once. If it makes you happy, spend the dough and get the machine you want. If the machine is in the condition you claim, I think $1,600 is a plenty fair price.
Put it on CL for a firm price or ask 20% more than you're willing to take so the buyer has the opportunity to haggle a bit. My guess would be that there are enough potential buyers in SW Georgia, for an item like that, that it'll be sold pretty quickly.
I think $1600 would be a very good price on it, and it should sell quickly. I wouldn't price it that way if you use CL…everyone there thinks you should offer less even if the item is already very fairly priced. Don't forget to list them in the classifieds section here and maybe other forums as well.
Good luck with the sale. In Hampton Roads VA that wouldn't last more than 2 hours and wouldn't go for less than $2K. Trust me…I looked for a year…literally.
$1,600 seems a bit low to me. Also, you always should ask more then you are willing to let it go for. Just about every buyer will expect you to come down a bit. I've also had the impression from comment an LJ's, that used SS tend to go fast. This would seem to suggest sellers are going a bit too low to start.
Bottom line, start high and see what happens. If you get no bites or even get negative comments along the lines of "who do you think you are asking so much for your saw", then you can always lower the price.
I'll hazard a guess that since you are looking to upgrade from a 3 HP PCS to a 5HP ICS (or do they make a PCS in a 5 HP), that money isn't really that much of a limitation for you. If money isn't that big a deal, you might consider donating it to a school or other. You'd get a good sized write off and add to your karma bank balance.
That new router table and lift accessory is available for the older saws. The note on the sawstop page says you'll need replacement rails. Seems to me that'd be a lot cheaper.
"Optimize your SawStop saw with this In-Line Router Table Assembly. On a Professional or Industrial Cabinet Saw, install this beautiful Cast Iron Table between the rails in place of your extension table (for saws purchased pre-RT launch, retrofit rails will be available and required). On a Professional, Industrial or Contractor Saw, optional installation to the left of the saw. "
Thanks again for all of the interest. I have a pending sale so I'm going to respect this (potential) sale before I talk to others if ok. I'm not looking to bid this to the highest…I am keeping at my asking price but will give the first person who already contacted me first dibs. If that does not go through I'll let y'all know.
To answer the question about the rail, it currently has the 36" fence on it. It also includes the mobile base.
Ok unfortunately that sale did not go through…no problem…but offer remains for Sawstop 3 HP Prof at $1,600…I would prefer to sell locally if someone can come pick up. Packing this up is going to be a huge pain so would rather not if don't have to. Anyone within driving distance want to come get?
I've yet to reach the limit of what my 3hp PCS can do.
I don't go for the idea of a router table in my tablesaw. I don't want to share the fence.
Every user's different I guess.
You have insufficient privileges to reply here.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
