Hinges
Forum topic by zipmac22 posted 12-17-2017 12:34 AM 353 views 0 times favorited 2 replies Add to Favorites Watch
View zipmac22's profile
zipmac22
29 posts in 1055 days
12-17-2017 12:34 AM
I’m making a set of corn hole boards and looking for a way to keep them together when not being used. I’ve seen hinges that seperate from the “pin” that connect both base plates. One side of the base plate has a hook or claw that slips under the pin and holds the two base plate together. On the other end of the corn hole board I thought I’d put a couple of latches to hold the two halves together.
I have seen these hinges I’m looking for, but can’t seem to find anything like them on-line. If anyone has any suggestions that might work I’m open to any suggestions. Thanks!
-- Chris, Central Texas
2 replies so far
13640 posts in 3543 days
#1 posted 12-17-2017 12:44 AM
called ‘loose pin hinges’
used for storm shutters
see if some of these might work
https://www.ebay.com/sch/i.html?_nkw=loose+pin+hinge&ul_noapp=true
View jerryminer's profile
jerryminer
944 posts in 1643 days
#2 posted 12-17-2017 01:35 AM
Simpler than a loose pin hinge is a “separable hinge” AKA casket hinge. No parts to lose:
Separable Hinge
