Best Grain Orientation for Steam Bending?
Forum topic by Lazyman posted 12-16-2017 03:53 PM 2307 views 0 times favorited 9 replies Add to Favorites Watch
View Lazyman's profile
Lazyman
2711 posts in 1629 days
12-16-2017 03:53 PM
Topic tags/keywords: steam bending question oak beech
I’m planning a project that requires steam bending and before ripping the strips I need to bend, it occurred to me that it might be easier to bend if I orient the grain in one way or the other. Is it better to have the growth rings parallel or perpendicular to the direction of the bend or does it make any difference? It seems like it would be less likely to split along the grain if the rings are perpendicular.
9 replies so far
View Rich's profile (online now)
Rich
4013 posts in 831 days
#1 posted 12-16-2017 04:34 PM
It’ll ultimately be stronger if you orient the grain along the bend. You wouldn’t build a shelf with the grain running front to back for the same reason.
The only reason I can see to have the grain across the bend would be for decorative reasons, like for a facia.
View jdh122's profile
jdh122
1060 posts in 3059 days
#2 posted 12-16-2017 05:06 PM
Getting wood with the least amount of grain runout is by far the most important. After that, if you can get air-dried instead of kiln dried it’s better. Otherwise most people seem to say that it makes no real difference whether you bend along the flatsawn or the quartersawn plane. I”ve not notice any difference, although I haven’t steam bent hundreds of times or kept rigorous records of my bending…
-- Jeremy, in the Acadian forests
Lazyman
#3 posted 12-16-2017 06:08 PM
Thanks Jeremy, that’s exactly what I was looking for.
View Loren's profile
10477 posts in 3889 days
#4 posted 12-16-2017 06:38 PM
Putting a small chamfer on each corner can
help prevent grain from slitting out. I do
it and haven’t really had problems.
I’ve read that flat sawn wood bends better
than quarter sawn.
I wouldn’t recommend getting obsessive
about grain runout, but say you want to
bend a 36” long piece of oak. There’s
usually some runout on the board you’ll
be cutting the blank from. I draw a line
along the grain, band saw to the line and
run it over the jointer, then rip parallel on
the table saw.
View lndfilwiz's profile
lndfilwiz
108 posts in 1842 days
#5 posted 12-16-2017 07:32 PM
Make sure you have your jig already built before you start teaming. I use to help a friend make bobsleds using 4X4 white oak for runners. We made a jig from a 16X16 beech log and placed a angle iron pocket on the front of the log The log was cut to the curve that we wanted the runners to be. We built a roller on heavy duty angle iron the pivoted around the curve ~ 4” from the curve. We used an electric winch to pull the roller/lever around curve jig. We let it sit for 2 days before taking it out. He made a 12” dia by 10’ long steamer. Made 10 bob sleds before he passed away!
-- Smile, it makes people wander what you are up to.
View shipwright's profile
shipwright
8188 posts in 3039 days
#6 posted 12-17-2017 01:19 AM
I always tell people to chamfer the corners as Loren said. In my experience (bending A LOT of ribs and planks in/on wooden boats) it is definitely better to bend on the flat grain than edge grain. In small bending however, it may not make a lot of difference.
Lazyman
#7 posted 12-17-2017 01:44 PM
Thanks. I will give the chamfer a try. The piece I am bending is just slightly over 1/8” thick beech and 1’ X 60” but is kiln dried (nearly impossible to fine air dried wood in DFW area) and I am making a pretty severe bend so anything I can do to prevent a failure may help. The first try with flat grain split. I read that soaking kiln dried wood may help so that is going to be my next attempt but without access to air dried wood, I might be wasting my time.
Lazyman
#8 posted 12-27-2017 04:36 PM
Success. I did chamfer and soak the wood strips but in the end, I think that using a metal bending strap was all it took to prevent the failure. I simply bought a small roll of roofing flashing at Home Depot, cut a strip the same width as the wood strip and screwed some wood blocks to the flashing so the wood strips fit tightly between them. There was quite a bit of spring back but it was still set well enough to work. Thanks for the advice. I’ll post project post shortly but here are some shots of the results.
shipwright
#9 posted 12-28-2017 12:06 AM
A hard setting glue like hide glue or urea formaldehyde will dramatically reduce spring back.
