Curved Doors
Forum topic by sIKE posted 220 days ago 418 views 1 time favorited 12 replies Add to Favorites
View sIKE's profile
sIKE
561 posts in 241 days
220 days ago
Topic tags/keywords: question milling shaping
I am in the process of designing a quarter round book/display shelf and have most of the major concepts worked out (at least in rough draft form). While explaining the design to my wife she asked if it would be possible to add some small doors to enclose the bottom bit of the shelf. I thought that it would look great, but am baffled in how to make curved cabinet doors that would work. Any ideas? The design is simple in form with some Shaker and some arts and crafts influences.
View GaryK's profile
GaryK
8489 posts in 475 days
220 days ago
You could build it in segments. Gluing a bunch of small pieces slightly beveled on the edges.
You could also do kerf bending. A bunch of saw cuts on the back side then veneer over the saw cuts.
View Peter O's profile
Peter O
633 posts in 361 days
220 days ago
Another way that Gary didn’t mention is to build a curved form and glue up several layers of veneer (or plies) to create the pieces.
If you are doing frame-and-panel doors, cutting the slot in the rails is going to be a trick! You might want to consider building the slot in, rather than cutting it afterward.
-- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com
dennis mitchell
2945 posts in 801 days
220 days ago
The wood species might have some thing to do with figuring out how you want to do the doors. You might even get by with just cutting them out with a band saw.
View John Ormsby's profile
John Ormsby
163 posts in 224 days
220 days ago
I just added some photos. One of them is of some curved pieces for a recent job. To cut the slots, you just make a jig in the curve you wish and run a plunge router with a down cut spiral bit. Unfortunately, I do not have any photos of this technique. I will post some photos the next time I need to do some curved work. It may be awhile, as I am quite busy with other project for now.
-- Oldworld, Fair Oaks, Ca
View Thos. Angle's profile
Thos. Angle
3236 posts in 449 days
219 days ago
If you are doing slab doors, there is a kerf board available that you can form and cover with veneer. It comes in 4×8 sheets. Here we can get it from Lumber Products.
GaryK
219 days ago
I don’t know if this is what Thos is talking about but I know of it as wiggle wood. It’s
plywood that’s not cross laminated so it bends easily.
Here’s now to use it.
http://members.aol.com/woodmiser1/bend.htm
You can get some here:
http://bd-international.com/Flat%20plywood.htm
View Les Hastings's profile
Les Hastings
469 posts in 260 days
219 days ago
What kind of door are you wanting to make?
one smooth surface, like a plywood door veneered or a style and rail door with a raised or flat panel?
What is the radious? Do you have a vacum bag set up?
-- Les, Wichita, Ks. (I'd rather be covered in saw dust!)
View Dadoo's profile
Dadoo
1536 posts in 477 days
219 days ago
Check this jock out!
http://lumberjocks.com/projects/1846
He’ll even write back if ya PM him!
View rikkor's profile
rikkor
7687 posts in 361 days
218 days ago
Sounds a bit daunting. Good luck.
-- Maplewood, MN
View sIKE's profile
sIKE
218 days ago
I started digging into this, Norm Did a Hanging Curved Cupboard. He made a nice looking curved doors on it. I have ordered the plans for his project in hope of using it on my project. Will let you know how things work out. I am going to have to build my Router Table first though.
View 8iowa's profile
8iowa
127 posts in 248 days
217 days ago
Woodworking author Nick Engler covers the making of curved cabinet doors in a recent on-line video clip, “Sawdust Sessions #13”
www.shopsmithacademy.com/Sawdust_Sessions.html
View EaglewoodsPres's profile
EaglewoodsPres
22 posts in 217 days
217 days ago
Lee hit it on the mark. A vacuum bag setup is the only way to go. Bending plywood, veneered on both sides and put in a form to match the radius. Make sure the form a “a pinch” over bent. Even plywood will spring a little after it is released from the forms.
-- Chris ( Eaglewoods@sbcglobal.net )
Bookmark And Share This Page
