Walnut for Coffee Table - To continue flattening or not?
Forum topic by Keith Kelly posted 12-15-2017 04:17 PM 599 views 1 time favorited 14 replies Add to Favorites Watch
View Keith Kelly's profile
Keith Kelly
279 posts in 1904 days
12-15-2017 04:17 PM
I used this project as a reason to buy a welder. The legs/base will be sand blasted to dull it up.
The Walnut i used for the top was a reject at a mill, set aside on the ground for 8 months, not stacked well. It has its fair share of issues, but it’s awesome. I partially surfaced both faces, but am focusing on the top.
There’s one spot on the top that’s lower than the rest. I can keep sanding 3/32” off of the top and will eliminate the low spot. But, that also reduces the thickness of the rest of the top 3/32”.
Options:
  • drum-sand 3/32” more to make it flat, then join them together.
  • Keep as-is. Leave a 1/4” space between the boards, chamfer the inner edges, and have a story to tell about where the wood came from.
What would you do? Lose 3/32”? What am I neglecting to consider?
-- Keith - Bolivar, Missouri, http://www.SquareOneWoodworks.com ... http://www.KeithsTestGarage.com
14 replies so far
View bbasiaga's profile
bbasiaga
1242 posts in 2236 days
#1 posted 12-15-2017 05:10 PM
Other option: route in a rebate where the two would meet and get a custom piece of glass to match. The you end up with one of those “river tables”, and a great story to tell about the wood.
Otherwise, if the 3/32 isn’t needed for structural integrity, which it does not seem to be, there shouldn’t be an issue sanding them both to match and doing a more traditional top.
Brian
View Carloz's profile
Carloz
1147 posts in 832 days
#2 posted 12-15-2017 05:18 PM
Keith Kelly
#3 posted 12-15-2017 06:06 PM
Otherwise, if the 3/32 isn t needed for structural integrity, which it does not seem to be, there shouldn t be an issue sanding them both to match and doing a more traditional top.
Brian
- bbasiaga
Good idea.
- Carloz
Not gonna happen, but I appreciate the humor.
Smitty_Cabinetshop
15822 posts in 2859 days
#4 posted 12-15-2017 06:08 PM
No other way to orient that non-live-edge piece to have the center line thickness equal? Then the thinner section goes face down OR to an edge.
Keith Kelly
#5 posted 12-15-2017 06:32 PM
- Smitty_Cabinetshop
Not that I can think of. I was aware of this low spot when I began the project. The other side is worse. I guess, putting the live edges in the middle may not be terrible. People do some cool things that way but it looks like a lot of work.
I’m leaning towards the sanding 3/32 route to make it a flat top. Kids will be playing with legos on this top, so removing voids would be a plus.
shoot, maybe a big enough gap that legos can intentionally fit through, so a bucket can sit underneath it to catch the legos that fall. Hmmmmmmmm…....
Smitty_Cabinetshop
#6 posted 12-15-2017 06:35 PM
^ Now you’re thinking!!
View sras's profile
sras
4970 posts in 3370 days
#7 posted 12-15-2017 06:40 PM
You’ve got some ideas, bit I have to say that is some beautiful wood!
View anneb3's profile
anneb3
45 posts in 1794 days
#8 posted 12-15-2017 07:07 PM
Only the top has to be level, no one checks underneath. Shim the bottom as necessary
Keith Kelly
#9 posted 12-15-2017 07:42 PM
- anneb3
yep, this is my plan. The bottom has much more unevenness.
Keith Kelly
#10 posted 12-15-2017 08:05 PM
apparently I made a double post. Feel free to delete this one.
View Aj2's profile
Aj2
1953 posts in 2039 days
#11 posted 12-15-2017 08:45 PM
Now that’s a table top. The grain and color is killer!
-- Aj
View Manitario's profile
Manitario
2705 posts in 3124 days
#12 posted 12-15-2017 09:48 PM
I’d just sand the low spot and not worry about that part of the top being level. You could also sand the matching piece to match ie. so that it’s the same thickness at that one spot.
View dhazelton's profile
dhazelton
2805 posts in 2537 days
#13 posted 12-15-2017 09:54 PM
Are you going to glue those together? If you use a biscuit joiner or Domino those would help align the top surfaces closer together than the boards just lying on the frame like we’re seeing. Keep the unevenness to the underside basically…
View waho6o9's profile
waho6o9
8539 posts in 2818 days
#14 posted 12-15-2017 09:57 PM
Amazing grain. I’d glue it together like you have it and sand it until it evens out, a little saucer
in the middle if you will.
Looking to see it finished in the project thread.
