Hot pan that chars cutting board
Forum topic by Benius posted 12-14-2017 03:04 AM 1690 views 0 times favorited 12 replies Add to Favorites Watch
View Benius's profile
Benius
24 posts in 557 days
12-14-2017 03:04 AM
Topic tags/keywords: cutting board char burn temperature oven safe wood
Hi everyone. I make 1.5” thick end grain cutting boards that generally consist of hard maple, purpleheart, walnut and cherry in different amounts. I recently gave one to a friend of mine and he loves to cook with cast iron. He asked if he bakes something in the over at 350-400 degrees, can he safely set the cast iron pan on the cutting board without damaging it. I had no idea. I assumed at that high temp it would leave char marks but I’m not sure. Does anyone know if it would char the wood?
PS I finish with mineral oil and glue up with Titebond III
Thanks ahead of time
12 replies so far
View TheFridge's profile
TheFridge
10815 posts in 1721 days
#1 posted 12-14-2017 03:11 AM
I would imagine there’d be some discoloration at the least.
View jerkylips's profile (online now)
jerkylips
483 posts in 2805 days
#2 posted 12-14-2017 03:15 AM
I wouldn’t risk it. That’s what trivets are for
View Rich's profile (online now)
Rich
3990 posts in 825 days
#3 posted 12-14-2017 04:56 AM
It would be pretty simple to heat a cast iron pan to 400º and set it on a piece of scrap wood treated with the same mineral oil to see what happens.
View jonah's profile
jonah
1971 posts in 3534 days
#4 posted 12-14-2017 04:58 AM
It seems silly to risk it. Why not just stick a trivet or dish towel down?
View Woodknack's profile
Woodknack
12455 posts in 2615 days
#5 posted 12-14-2017 05:18 AM
400f isn’t very hot, not really. I think they will be fine but it wouldn’t hurt to test on scrap as different wood species will burn at different temps. I set hot pans on my cutting boards and wood trivets all the time and have never scorched one.
View Carloz's profile
Carloz
1147 posts in 827 days
#6 posted 12-14-2017 01:03 PM
The big cutting board I just made from 8/4 hard maple already has charred circles from the frying pan. But why would I care ? If you want it to look pristine put it in a frame under glass and hang on the wall.
View bondogaposis's profile
bondogaposis
5149 posts in 2586 days
#7 posted 12-14-2017 01:15 PM
I’m with Fridge on this, discoloration for sure. Just the tannin reacting with the iron alone could do it, add heat and well, it’s gonna leave a mark.
-- Bondo Gaposis
View HorizontalMike's profile
HorizontalMike
7770 posts in 3149 days
#8 posted 12-14-2017 01:22 PM
When my cutting boards get all cut up with cut marks, I run it/them to the shop and get out my 1/4-sheet sander. Looks like new again, and then I return it to use. Problem solved…
I would venture to guess that sanding might also eliminate/reduce any char marks as well… My 2-cents worth…
View Knockonit's profile
Knockonit
502 posts in 437 days
#9 posted 12-14-2017 01:34 PM
Ole gal i live with gave one to a friend, and she sat a skillet on it, while it didn’t char it, it did leave a rather ugly brown ring and spots,
before i knew it i was given the task to repair, drum sander, although the oil was still recent, kinda gummed a bit, but after cleaning sanding paper a couple times, got it back to original and gave it a bath. looks like new.
we’ll see if the gal is smart enough to not do again. argh.
View rbrjr1's profile
rbrjr1
170 posts in 441 days
#10 posted 12-15-2017 02:03 PM
I wouldn t risk it. That s what trivets are for
- jerkylips
THIS…
Hot pans belong on granite countertops or trivets..
Why would someone set a hot pan on a cutting board?
-- only an idiot dismisses an intelligent statement because they dont know anything about the person delivering it.
View mudflap4869's profile
mudflap4869
1883 posts in 1694 days
#11 posted 12-15-2017 03:37 PM
Fajitas come in a cast iron skillet, on a board. Charred? Yep, but that is what it was made for. Using, not admiring.
-- Still trying to master kindling making
HorizontalMike
#12 posted 12-16-2017 08:04 PM
- mudflap4869
+10 Especially down here in occupied northern Mexico…
...from ~30mi. north of the Alamo… ;-)
