dumb question re: miter slots
Forum topic by jerkylips posted 12-13-2017 05:45 PM 405 views 0 times favorited 5 replies Add to Favorites Watch
View jerkylips's profile
jerkylips
483 posts in 2806 days
12-13-2017 05:45 PM
Are the slots consistent from one model/brand to another? Specifically, the location on the table relative to each other and to the blade.
I have a couple jigs I was thinking about making, but a new table saw is in my grand plan in the not too distant future – just wondering if anything I build now would have to be rebuilt later?
5 replies so far
View Loren's profile
10477 posts in 3883 days
#1 posted 12-13-2017 05:51 PM
No. Rarely from brand to brand but sometimes
from model to model they may be consistent.
I’m sure a lot of cabinet saws are similar but I
wouldn’t expect a crosscut sled with two runners
to be interchangeable. I would make the runners
movable.
...and yes, probably.
View MrUnix's profile
MrUnix
7106 posts in 2434 days
#2 posted 12-13-2017 05:58 PM
Most mid to upper range saws are more or less standardized on 3/4 X 3/8. Bench top things are hit and miss, with a lot having 5/8 wide slots, sometimes T-shaped, and sometimes with little tabs protruding into the slot. As far as placement – absolutely not [1]. You can not take a sled made on one machine and use it on another as-is, usually even if it is the exact same brand/model due to differences in blade alignment/table placement. When you sell your saw, sell the jigs along with it and make new ones. On a positive side, the second version is always better than the first :)
[1] I know somebody will come along and said they did, and there is that 0.1% chance that it will work. But that is the exception, not the rule.
View splintergroup's profile
splintergroup
2500 posts in 1458 days
#3 posted 12-13-2017 07:22 PM
Note that the “standard” 3/4” miter slot has a rather broad industry tolerance of probably +/- 0.015” My Unisaw slots are so oversized, many aftermarket items wont function properly.
jerkylips
#4 posted 12-13-2017 07:33 PM
Pretty much what I figured, but thought I’d ask. I love the positivity of the comment “the second version is always better”!
View ArtMann's profile
ArtMann
1215 posts in 1051 days
#5 posted 12-13-2017 08:09 PM
I had to remake my crosscut and miter sleds when I sold my contractor saw and bought a hybrid saw. If I had only used one runner instead of two, there is a slight chance they would have worked. It would be a wild coincidence if the distance from the miter slot to the saw blade (and kerf) were the same. Typically, that is a requirement. I can see how some things could be designed for multiple saws but you will have to always keep compatibility in mind.
