Correcting a Machinist Square
Forum topic by BassBully posted 2249 days ago 1938 views 0 times favorited 16 replies Add to Favorites Watch
View BassBully's profile
BassBully
258 posts in 2269 days
2249 days ago
Does anyone know if a machinist square can be corrected? I purchased two machinist squares from MLCSWoodworking because they were on sale. One of them is pretty darn close to perfect but the other is slightly off. Any ideas will be appreciated.
-- There are three types of people in the world, those who can count and those who can't!
16 replies so far
View Rob McCune's profile
Rob McCune
123 posts in 2270 days
#1 posted 2249 days ago
An machine mill should be used to machine it accurately. There should be an autmotive machine shop nearby, ask them to correct it for you.
-- Rob McCune
View Jeff's profile
Jeff
1011 posts in 2265 days
#2 posted 2249 days ago
I just read and article on this type of thing recently… I can’t remember if it was ShopNotes, FWW or Woodsmith though. I’ll see if I can find it. Rob’s idea sounds like it might be the best way though.
-- Jeff, St. Paul, MN
dennis mitchell
3994 posts in 2486 days
#3 posted 2249 days ago
I’m thinking pound on it with a hammer.
34370 posts in 2572 days
#4 posted 2249 days ago
I’m thinking return it and ask for an exchange. If its out of square it’s their problem
View scottb's profile
scottb
3648 posts in 2499 days
#5 posted 2248 days ago
I know you can fix a carpenters square with a hammer or a drill…
-- I am always doing what I cannot do yet, in order to learn how to do it. - Van Gogh -- http://blanchardcreative.etsy.com -- http://snbcreative.wordpress.com/
View Obi's profile
Obi
2202 posts in 2409 days
#6 posted 2248 days ago
Now we know why it was on sale, but sorry. What exactly is a machinist’s Square anyway?
-- http://ye-olde-cabinet-shoppe.com/
BassBully
#7 posted 2248 days ago
Obi,
A machinists square is like a regular square but it is suppose to be accurate within +/- .002” tolerance or so. They’re usually made out of steel.
#8 posted 2248 days ago
Obi: a machinist square is used to setup machine tools. All steel with heavy steel on the base and a steel bar at 90 deg. Harbor Freight carries them and I’ve found them to be accurate.
View WayneC's profile
WayneC
9596 posts in 2269 days
#9 posted 2248 days ago
Machinist Square
View jpw1995's profile
jpw1995
371 posts in 2470 days
#10 posted 2248 days ago
I have the Groz set that Wayne has pictured above, and they’ve been very handy to have around. I’ve found them to be very, very accurate.
-- JP, Shelbyville, KY
View Obi's profile
Obi
#11 posted 2248 days ago
I think them r cute, but I use a combination square, or a speed square, or a carpenter’s square.
WOW.
WayneC
#12 posted 2248 days ago
You can use these to check your combination squares, speed squares, and carpenter’s squares. : ^ )
Actually, they are great for checking tablesaws, drill presses, and jointers.
BassBully
#13 posted 2248 days ago
I’ll probably just try gently tapping it with a hammer. There’s very little information on the internet about this. If that doesn’t correct the problem, I’ll just send it back.
View Bill's profile
Bill
2579 posts in 2333 days
#14 posted 2247 days ago
Since it is supposed to be very accurate, I would send it back for a replacement. Accuracy is what their selling point is after all.
View coloradoclimber's profile
coloradoclimber
547 posts in 2239 days
#15 posted 2237 days ago
I have a similar problem, out of square machinist and wood handled tri-square. I have the following squares I use:
1 – Standard metal framing square, not particularly square, but works fine for framing and laying out stairs. I don’t expect great accuracy, it doesn’t deliver great accuracy, we’re both happy.
2 – plastic speed squares, you know, the bright orange or yellow triangles with a hook along one edge. Not particularly square, but not too bad. I use these things all the time for construction marking. Anything structural, framing, decking, things where a little slop is acceptable. These things are fast, convenient, cheap, and plenty close enough.
3 – Starrett hardened combination square. This thing is dead on. I checked it on the surface plate at work against multiple references. It was pretty pricey but I’d recommend it hands down. It operates smooth, very accurate, and you can do a lot with it. If I could only have one square in my entire shop it would be this one.
4 – el-cheapo combination square from HD. It turns out this thing is pretty accurate. I guess it doesn’t cost much more to mill it square than it does to mill it out of square. The faces are not hardened, the quality is not there, it sticks when it moves. Not a particularly quality tool but it is pretty darn square. For a beat around square I’m pretty happy with it.
5 – A set of Brown and Sharpe machinist squares. These are my standards. They are dead nuts on. I got a set of 4 and they are all less than a mil out in any dimension. Kinda pricey. I don’t typically use them except to check or verify other tools. In general I wouldn’t recommend having a set. I don’t really get much utility from them other than the comfort of using them as references for other tools.
And now my problem children – I wanted a beat around machinist square for tool setup, and at the same time I thought I’d look like a cool woodworker if I had a rosewood handled brass pinned tri-square. So I picked up one of each from a local woodworking specialty store. I admit both were cheap and I ended up getting what I paid for.
6 – 6 inch machinist square. It’s out of square about a 64th, around 15 mils, at the end. It is more out of square than my jointer. I can mill a board square (checked with a reference square) and this tool will say the board is out of square. So I’m hating this thing. I think I’m going to try to square it myself by lapping edge of the blade. If it doesn’t work, oh well, I’m not out that much money and I haven’t ruined a tool I care about. If it does work I’ll have a tool I can be happy with.
7 – 8 inch wood handled tri-square. This thing is so far out of square it’s a joke. It is close to a 32nd or more out at 6 inches. It kinda looks cool and I drag it out and set it on the bench when I’m in the shop but the reality is this thing is junk as a square. I don’t know if it’s possible to adjust these things and have them remain adjusted. The blade is pinned to the handle with brass rivets. It’s not clear to me that it’s possible to adjust it without ruining the handle to blade joint. I’ve considered lapping the blade to true it but it’s not worth my time.
So my conclusions and recommends:
1 – You get what you pay for.
2 – if you can only have one square, save you pennies and buy a Starrett or Brown and Sharpe combination square, you’ll never be sorry.
3 – if you cant afford a high end square try a cheapo from your local big box hardware store. You might be surprised, I was.
4 – if you bought a square that is guaranteed to some accuracy and it doesn’t meet that accuracy, take it back. I figured it would be a crap shoot with any low end tool so I’m inclined to try to clean it up myself (probably a waste of my time)
5 – If you like the looks of the brass and rosewood handled tri-squares, then by all means buy one. But if you want it to be actually square take a reference with you and confirm it before you buy it.
I know the old saying, it’s wood working, not machining. But the reality is if you want your joints to come together clean with the least muss and fuss then having your tools setup properly and starting with boards and joints that are square and true will only help. A 32nd out in 6 inches is an 8th out in two feet, and a quarter out in 4 feet. Try to get those joints to line up.
